problems , No power boost, black smoke , check engine light come on and off,
I replace ECM computer, ECM Harness, turbo , water pump, sensors ,V-pot , EGR valve , replace manifold seal , and my truck still having he same problem
Freightliner Columbia 2007
Discussion in 'Freightliner Forum' started by Freightliner 2007, Aug 23, 2017.
What code is stored in ECM when it is read with laptop?
try boost sensor or maybe delta p lines are plugged also make sure to check that your egr is not stuck open
better to diagnose properly than just change a bunch of parts
QUALITYTRUCK Thanks this. -
Delta P sensor or boost sensor........
I'm confused.i thought black smoke means the injectors are bad.
