Freightliner headlight issue.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DuesyJ29, Jul 25, 2020.
  1. DuesyJ29
    DuesyJ29 Light Load Member
    78
    35
    Jul 19, 2013
    Dallas, Texas
    Wondering if anyone has run into this problem.
    2016 Cascadia, and I keep melting the headlight plug on the left side. I’m getting 36 volts at connector, but can’t figure out how. Wondering if anyone has any ideas? So far it takes about two weeks for the connector to go bad.
    Thanks,
    MS
  3. AModelCat
    161,506
    Yeah something's screwy there. Not sure how you'd get 36 volts out of a 12 volt system? Are you sure you had the meter set to measure DC power and not AC? That can give you some really messed up readings.
    spsauerland Thanks this.
  4. DuesyJ29
    78
    35
    Jul 19, 2013
    Dallas, Texas
    Yeah, I’m pretty sure. My uncle is helping me, he seems to think I’ve got a bleed over of some kind, but where or how could I be getting 36 volts?
    ms
  5. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    I dont know about the voltage but i had the same problem after upgrading lights on a fld.
    Kept melting the plug,what i did is change the gauge of the wire to a heavier gauge as far back as i can go,problem solved
