Freightliner Cascadia 2012 DD15 DEF loses power
Discussion in 'Freightliner Forum' started by birsadorin24, Jun 27, 2017.
  1. birsadorin24
    birsadorin24 Bobtail Member
    My truck is loosing power in seconds , after 3-4 seconds the power is returning. That happens as many times as it wants, anytime, anywhere. When is loosing the power the check engine is not on. A second after loosing the power the radiator fan starts for 10-15 seconds. Sometimes the check engine is on and it shows SPN 108 BAROMETRIC PRESSURE 13 . I did 2 diagnoses at Freightliner dealership and is not showing any active faults and the mechanics don't know where from to start the repairs. Thanks and hopefully someone will help me. The truck is Freightliner Cascadia 2012 DD15 DEF
  3. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    I just won a fight with this same problem after 3 day battle at my shop. Save yourself a headache and replace the engine harness. $350 harness. 5-6 hours labor. Trust me on this one.
    brysol01, simo omnis and birsadorin24 Thank this.
  4. xsetra
    xsetra Road Train Member
    4,928
    6,588
    Aug 21, 2011
    Sounds like a loose contact or a short somewhere in your harness.
    Good luck. Electric gremlins are hard to find sometimes
    birsadorin24 Thanks this.
  5. Rmanuel77
    Rmanuel77 Bobtail Member
    I am having the same exact problem! Did you ever figure out what it was?
  6. me myself and I
    me myself and I Heavy Load Member
    716
    308
    Oct 5, 2009
    vernon hills,Il
  7. mhyn
    mhyn Road Train Member
    4,255
    4,502
    Dec 29, 2008
    Northridge, CA
    the mcm has baro sensor mounted on back side. Some times pressure washing kills it.
