Freightliner Park Smart Apu Heat works for 30 min after truck shut off then quits
Discussion in 'Freightliner Forum' started by LakenT, Jan 29, 2023.
  1. LakenT
    LakenT Bobtail Member
    20
    Jun 19, 2022
    We run the parksmart apu on our trucks. I have noticed after 30 min the heat stops after truck is turned off. I have check all batteires. The air still blows but the heat quits. What is the fix to this. Could it be heater core?
    Thanks!
  3. SWM_TECH
    SWM_TECH Light Load Member
    83
    82
    Apr 15, 2018
    Does this have auxiliary diesel fire water heater? I don't have much first hand experience with troubleshooting the Park Smart but would like to learn. If you would post the last 6 digits of your VIN we get you more accurate information.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    1,920
    4,890
    Oct 22, 2016
    North Dakota, Eh?
    When's the last time the heater was serviced? We usually get 1 to 2 years before they need to be gone through. Little screen in the combustion chamber gets crappy and it wont tun.
    Dave_in_AZ Thanks this.
  5. LakenT
    20
    Jun 19, 2022
    Thanks I just bought a new one and will rebuild the old one.
    Crude Truckin' and Dave_in_AZ Thank this.
  6. Dave_in_AZ
    248,406
    Knock on wood, ours is working like a champ. It heats the block too. 10 degrees outside, water temp in block is 150.
    Crude Truckin' Thanks this.
Draft saved Draft deleted
