Freightliner Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AACT98, Jan 25, 2009.
  1. AACT98
    AACT98 Bobtail Member
    4
    chicago, IL
    I have a Detroit 60 series in a 2001 freightliner century class S/T, My problem is that the engine is not taking oil, but it also burns to much fuel in my opinion its getting 5.2-5.4 miles per gallon, this freightliner has an eaton automatic transmission, and when it switches gear it exerts a noise such as a Jake-Brake when it is off, but it switches gears fine when it gives off that kind of noise, but some times it gives off a squeling noise, then the gears shift rough from 3-4 and 9-10 and on the 10th gear when driving it gives off the squeling noise. if anybody has any idea what my problem maybe please send me an email.
  3. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I would say that the transmission needs looked at asap. It maybe on its last leg. From what you describe I think the motor is fine. The only thing I don't understand is "the engine is not taking oil". If you don't have to add oil in between oil changes, thats a good thing.
  4. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    We've got a T-600, Detroit, 10 spd autoshift, I'm not sure about the squealing noise, but the jake brake coming on sometimes is probably normal. I think the computer is telling the engine to do that to make sure the engine slows down quickly enough to complete the shift. Ours does it more when loaded, in the lower gears, but will also do it sometimes when it is empty in situations where you wouldn't think it would be necessary. A friend of mine told me about a trick, if you don't want the jake coming on between shifts, take your left foot and touch the clutch pedal just enough to open the jake switch on the pedal, and it won't activate the jake brake. But there are a lot of times when it almost has to have the jake "burping" between gears to make the shift- taking off loaded, turning a corner loaded and shifting at the same time for example.
    Ours sometimes shifts a little rough going from 5th to 6th, kind of grabs, instead of smoothly going into gear. Not sure what to tell you about the squealing, I'd change the tranny oil and see what the old oil looks like.
