Freightliner vs Kenworth
Discussion in 'Questions From New Drivers' started by Lonewolf2000, Nov 15, 2017.
  1. Lonewolf2000
    Lonewolf2000 Medium Load Member
    310
    322
    Nov 5, 2017
    New York
    Just curious to hear from someone who has driven both the Kenworth T680 and the Cascadia not the newest version but the outgoing cascadia. So you drivers like one better than the other in terms of handling ride comfort/ amenities etc. Or are they pretty much the same.
    Steel Dragon, IluvCATS and Lepton1 Thank this.
  3. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Comparing a Kenworth to a Freightliner- hmmm.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    I like the KW series trucks across many years. The T2000 represented for us a palace with power and grace.
    Now that I got the BS out of the way the 680 is a working truck, nothing special about it really. If you want Class try the W900 series.
    Freightliner bends over backwards so much every few years redrawing something that was #### good for what they built decades ago and keep screwing up. Thus crapcadia to me. (No offense to those who do run them... it's just that my taste stopped with the 120's and centuries.)
    They used to build day cabs with long noses and #####ing power with transmissions to match. Those days are gone forever. You should try one of those at least one time in your life.
    Steel Dragon, Highway Sailor and 201 Thank this.
  5. WesternPlains
    6,288
    51,559
    Sep 1, 2017
    I've had experience with paccar. No thank you.
    buddyd157 and x1Heavy Thank this.
  6. bigguns
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Peterbilt and Kenworth are like apples and oranges.
    montrose818 and x1Heavy Thank this.
  7. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    I haven't been in the T680, but I think the Cascadia is one of the worst designed Freightliner's ergonomically. The dash display is blocked by the steering wheel, the rocker switches are blocked by the cups in the cup holders. The windshield leaks in the center, the hood latches are junk, the cb mount sucks, the a/c vents are blocked by the top of the steering wheel, some of the other rocker switches are blocked by the steering column, it has no external visor to block the sun. That's just a start.
  8. x1Heavy
    34,017
    42,130
    Mar 5, 2016
    The 680 was a bit of a shaker compared to the T2000. I remember taking one to texas as a subsitute shop queen. Those plates on the old 30 prior to construction hurt my back a little bit but in those days a little shaking was normal to me.
    Steel Dragon Thanks this.
  9. free2frog
    free2frog Medium Load Member
    437
    155
    Sep 15, 2009
    Indianapolis, Indiana
    I miss the leg room I had in the FL and the turning radius other wise Ill keep my 680
    Steel Dragon and x1Heavy Thank this.
  10. 386lover
    386lover Light Load Member
    95
    107
    Oct 24, 2017
    KW great for comfort. If you're o/o cascadia for cheap and reliable.
  11. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Cascadia's do have external visors. They re optional
