Frequency Counter
Discussion in 'CB Radio Forum' started by BTShepp, Feb 6, 2017.
  1. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Picked up a new toy from Steel Rod's in Indiana I-65 exit 201. $32 with tax. I know I don't necessarily need this to use the radio, but it looks nice and I can see what those mystery channels are in the different bands.
    I noticed the sixth digit changes sometimes. On channel 19, it can alternate between two and three. Is this a problem, or is that error negligible with a.m. radio? (No SSB on the General Lee.)
  3. Ridgeline
    22,192
    113,897
    NO it is way off, if it was 4 or 6, well OK but not 2.
  4. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    @Ridgeline I promise I won't let this distract me from staying in my lane.
  5. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Can't tell if that's sarcasm or not…
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    I can't find a chart that goes to 6 digits. Do I assume channel 19 is 27.1850?
    fargonaz Thanks this.
  7. Ridgeline
    22,192
    113,897
    No it isn't.
    The counter is off, there is an adjustment inside that can fix that. If it said 4 or 6, either side of 5, I could see it being slightly off but 2 is too much.
    EDIT
    OH CRAP, sorry BT, I am looking at a 6 digit counter which I thought was a 5 digit counter.
    OK disregard all of it except the part about adjusting it. It should be zero. Every CB channel is five digits so in a six digit, it is always zero. 27.185 is 27.1850.
    BTShepp Thanks this.
  8. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Could it be the radio? Or definitely the counter.
  9. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Ah 10-4. I found this chart to six digits, as well. Let's be honest, you and I both know this is more for decoration then function. Although I do like to know that things work properly.
    http://www.radioreference.com/apps/db/?aid=7731
  10. hayseed
    hayseed Light Load Member
    211
    109
    Dec 31, 2011
    The Natural State
    BT, Have you had the radio checked to see if it is dead on freq?
  11. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Kelly Poots worked on it in October and said he made sure it was aligned. That's all I could tell you.
    The counter was sitting with the other used radios/equipment at Steel Rod's shop.
    If the radio is off by 0.00003 MHz, does that really effect AM?
