Front axle weight
Discussion in 'Experienced Truckers' Advice' started by lwlevens, Feb 19, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Hi guys been looking at this 05 mack granite triaxle dump,what is the minimum front axle weight for a triaxle truck? Also I think it is a single frame. Thanks in advance. I'm in Pa. which the gvw is 72,320
  3. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Minimum weight?
  4. lwlevens
    623
    427
    Feb 9, 2018
    Yep usually front axles are 18,000 20,000 lb fronts.Just wondering would a 12,000 or 16,000 lb front axle be safe for a tri axle.
  5. Travisroland
    Travisroland Light Load Member
    236
    139
    Apr 2, 2015
    When you open the drivers door there should be a sticker telling you what the steer axel is rated for and the size tires you should be running.State Regs for the roads you want to run on is another thing.If the road is not rated for that weight you need to stay off it unless you have the right permit
  6. lwlevens
    623
    427
    Feb 9, 2018
    I know but can't make out the tag it's worn out. Would the vin# work to find out the front axle weight?
  7. countyrebel05
    countyrebel05 Bobtail Member
    8
    Oct 18, 2016
    Yes they can give you the build sheet off the vin for the truck at the dealer
  8. lwlevens
    623
    427
    Feb 9, 2018
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    What size are steer tires? Most dumps have float tires on front so 18,000 fronts usually.
  10. lwlevens
    623
    427
    Feb 9, 2018
    Yep they are floats I think they're 425's
    Oldironfan Thanks this.
  11. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Most generally your 18000 and 20000lb front axles will have 2 steering boxes one on each side of the frame and large diameter king pins.
