Front Brake Problem, please advise.
Discussion in 'International Forum' started by Treebutcher, Apr 22, 2013.
  1. Treebutcher
    Treebutcher Bobtail Member
    11
    At around 15 lbs application pressure at road speeds get a vibration that increases in intensity through steering as application pressure increases.
    At low speeds, approaching a stop, the vibration turns into more of a lope.
    Seems to be more affecting the steering side drum.
    I see no obviously damaged components.
    Int. Lonestar, 2013.
    Please advise.
    Thanks.
  3. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    i had that problem on a pete dumptruck. the drum was warped really bad as if it were bent.
    lift the front off the ground and spun the tire, you could actually see the spacing between the brake and drum vary. mine was the right side.
    Treebutcher and CondoCruiser Thank this.
  4. Treebutcher
    11
    That's the only logical thing I can come up with as well.
    I'm not a mechanic but it makes sense as everything else appears solid.
    Only other question now is it safe? Or could this problem potentially damage another component that would lead to a brake failure?
  5. snowwy
    20,590
    13,308
    Jul 6, 2009
    as drums get warped. they require more and more pressure. becuase the drum isn't perfectly round. so it's not making 100% contact with every square inch of the brake shoe. the more it warps, the less actual contact.
    since you've only got one drum with the big problem. it's not working as hard as the other good drums. your applying more pressure then needs to be to get the one drum working. so the other drums are working harder then need be. which means wearing those brakes faster, making those drums hotter and they'll eventually start warping.
    if you want to keep the repairs down to a minimum. best to fix the problem. cuz problems only get worse.
    one of my first cars i had was a 75 plymouth duster. 4 drum brakes. brakes sucked, pedal was like hitting a brick wall. had all 4 drums machined. brakes worked like a champ afterwards.
    unfortunately, truck drums don't get machined, they get replaced.
    CondoCruiser and Treebutcher Thank this.
  6. Treebutcher
    11
