Noticed the seal leaking on the front drive, output shaft. I replaced both u-joints on that shaft about a year ago and keep’em greased regularly, along with the slip yolk. Once under the truck I pushed up on the yolk and noticed some movement. More movement than I like. I think there’s a 12 point 3/8” bolt or two, that hold the seal. Once I drive the u-joint out, remove the nut and pull the yolk, is there another set of bolts that hold the shaft in? Is there just 1 bearing?
Front drive output shaft play
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Aug 8, 2023.
I really think that once you remove the yoke the seal can be removed like most seals by prying it out and driving in a new one with seal driver preferably. I think the bolts you reference, are holding the bearing retainer to the housing.
The output shaft is unneccesary to pull and only comes out from inside the housing, if the seal is leaking, inspect the yoke for pitting. theyre relatively cheap. did mine 2 weeks after i replaced the differential while i was on the road...mile marker 27 Thanks this.
Repair sleeves are also sold for yokes and spindles. The sleeve/ring goes over the worn/grooved surface.Last Call and skallagrime Thank this.
What about the play that’s in the yolk/shaft?
That's a different problem. Most likely have a bearing going out. Make sure the nut is tight that holds the yoke on. If no other problems and only a seal leaking the repair sleeves can be used instead of buying the yoke.mile marker 27 and Big Road Skateboard Thank this.
Like @JB7 mentioned, gotta make sure the nut is tight firstBoxCarKidd and mile marker 27 Thank this.
I’ll tear into it probably Thursday. I was just in there about a year ago, to put a new seal in. I tightened the nut with a 3/4” impact and thought I had it plenty tight. Where the yolk slides on the splined shaft, is there a bushing behind the seal? I apologize, the truck is a ‘87 379, with 3:55 rears.
Absolutely. That’s what I did when I replaced that seal and U-joint, last year.
What’s the torque specs for the nut? I’ll probably buy a new nut and if it appears I need a new yolk, then I’ll get one of them too.
