Front driver wheel intermittent grinding on highway when it’s windy and a semi passes
Discussion in 'Freightliner Forum' started by MicCak, Dec 1, 2020.
  1. MicCak
    MicCak Bobtail Member
    2019 freightliner sprinter front driver wheel intermittently grinds and feels like it’s sticking quickly when I’m on the highway and a semi passes and it happens more when it’s windy. Makes the van wobble. (It is top heavy, thermo king.) Has anyone else had this problem of any idea what it could be? TIA
  3. bad-luck
    bad-luck Road Train Member
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like a wheel bearing. I would get it checked out ASAP! I wouldn't drive it. You can check it yourself. Jack up the wheel off of the ground and check if there is side to side movement
    MicCak Thanks this.
  4. MicCak
    Thank you, appreciate it
