Front End Shakes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bullseye62, May 22, 2013.
  1. Bullseye62
    Bullseye62 Bobtail Member
    29
    NC
    I have a 2007 Intl 9400i and am experiencing a bad front end shake and wobble between 45 - 65 mph. I had a three axle alignment done, and had new Kelly KDA tires put on the steer and front drive axles hoping that would solve the problem No such luck. What else could be causing the shake and wobble?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    tires out of balance or out of round or a brake drum out of balance. for starters.
  4. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    alignments only cause it to pull
    shaking is always something out of balance
    worn steer parts etc
    you need a new mechanic if they dont look for something else
  5. Bullseye62
    29
    NC
    They put a liquid balance in all of the tires, supposed to work....don't know yet. These are brand new tires, so I hope it is not out of round. Will also check the brake drums.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    have you checked the ride height on the air bags.
    A quick "field check" is that the top of your frame rails should be even with the top of your drive tires as a general rule. Pretty much you can lay a board across from one set of drives to the other side and the frame should be right there with the board.
  7. Bullseye62
    29
    NC
    I hear ya loud and clear on the new mechanic. I will have them check out the steering parts as well.
  8. Bullseye62
    29
    NC
    I haven't personally done the board test, I just had the dealer check the frame and all is good they tell me.
  9. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    Board test? That might be the dumbest post ever. How do you account for different tire sizes? Peterbilt has 5 different rear suspensions, all with a different ride height... factor in 4 different tire sizes, and you have 20 different relationships between the tires and the frame!
    Is it a side-to-side shake, or an up-and-down bounce? Do you feel in in your feet or the steering wheel?
  10. Bullseye62
    29
    NC
    It is a side to side shake and I feel it in the steering wheel.
  11. MNdriver
    7,985
    4,371
    Feb 24, 2012
    It's a field check. And until you actual go out and SEE what I am talking about it, try being open minded. It gives you a place to start. I didn't say it was to replace the actual check for the suspension. Discounting without checking it out further is just as silly if not more.
    If it's side to side, you are likely dealing with more issues than just an alignment. wheel bearings, Tire belts (but they are new you say) are normally a low speed shimmy. Typically under 30 mph.
    Higher speed shimmy (over 45) are balance issues. Check your brake drums for counter weights too. Make sure you didn't throw one there.
