Front Tire wear front edge couping. on new tires after alignment! Could it be kingpin
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Oct 4, 2014.
  1. Big Lou
    Big Lou Light Load Member
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Put on New Front steer tires did 3 axle alignment. My front tire is riding on outside edge. Couping all the way around on edge??
    Could it be bad King pins.
    Even after the alignment truck was still pulling to the right. I thought it was the way the road was slanted for water to roll off. But now I see the tire wear and there is definitely a problem.
    I was trying to upload a picture but could not do it.
  3. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    It could be. It could not. A very thorough front end inspection needs to be performed, as well as rear end suspension components. I have found in my years of working on trucks, tire wear issues and pulling issues can be very different causes but similar symptoms sometimes. King pins are easy to check, just need a long bar and a jack.
    Big Lou Thanks this.
  4. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    What other things should I be out for the look out. Because if I can narrow down to a few main possible issues to look at first it might save me thousands! As I just put a new Turbo on my truck with the help of a friend Rawze who saved me a lot of money. If anyone knows or remembers him great person and very helpful and full of knowledge. Thanks
  5. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    If you did alignment then your tie rods should be ok. Hopefully, you or the tech that did the alignment checked those. Kingpins could be an issue, pry on them a lil and check for play. If the tire is wavy on the outer edge, my money is on your shocks. It's a cheap fix that's easy to change.
  6. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    I put new shocks before the tires. They are not wavy at all the edge completely around the outside is wore. It's like the tire is only riding on the outside thread no where else really weird.
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    If you have high mileage, check the frre play in steer hub bearing assembly also;I replaced mine both street hubs at 1 mil miles after getting a strange vibration all the way to steering wheel.
  8. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    What air pressure do run in your steers?
  9. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    If you have a pull after an alignment, then I'd suspect that the alignment was nfg. If you have steering components that were bad, an alignment shouldn't have been performed before repairs were done - the shop should have called you for authorization to remedy the problem first. You can check king pins as others have described. Tie rod ends too. Wheel bearings too. After that check for damage like a bent rod joining the steering knuckles. If all checks out, get another alignment done.
  10. Ribeye
    Ribeye Light Load Member
    151
    119
    Jan 4, 2012
    Agree with all that.
    Who did the alignment, a good tire shop? did they use the laser alignment tools? I know some shops still don't want to upgrade.
  11. Flightline
    Flightline Road Train Member
    2,345
    1,166
    Oct 1, 2011
    Almost There
    If you got some help, check the alignment yourself and the kingpins and the complete front end.
    First have someone work the wheel back and forth while you find any play on any steering componets.
    If none, jack the front wheels off the ground, the check for any play in the wheels up and down with a bar for kingpins and wheel bearings.
    To check the alignment measure the distance inside the wheels from wheel to wheel accuretly. Should be 1/4 closer in the front. I've used couple pvc pipes with one inside of the other, lock them together, pull out and measure.
    I've had a respectable shop get the alignment off by and inch and not acknoledge it.
    Personally I don't beleive a laser alignment is any better, it's how good the mechanic looks over the job.
    Also know of big LTL carrier shops that use the stick and tape measure to set alignment with great accuracy.
    Big Lou, tsavory and BigJls1 Thank this.
