Frozen door locks
Discussion in 'Ask An Owner Operator' started by RERM, Feb 6, 2015.
  1. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Already tried DeIcer.....no luck, any suggestions?
  3. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    Lighter, hot water, light taps with a hammer, screwdriver...
    What do you drive? Sometimes there's some really creative ways to get inside those...
  4. RERM
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    2006 Freightshaker Century Class
    Chinatown Thanks this.
  5. Chinatown
    Chinatown Road Train Member
    74,999
    170,975
    Aug 28, 2011
    Henderson, NV & Orient
    I have heated the key with a cigaretter lighter and that worked. Let the key get real hot.
  6. XCELERATIONRULES
    XCELERATIONRULES Medium Load Member
    492
    492
    Dec 29, 2014
    I always carry windshield deicer,large can,not the small injector type.
    liberally spray the door, handle, and key.
    I buy it up in spring at all the dollar stores.
    works great on windows, and cuts down scraper time.
    DoneYourWay Thanks this.
  7. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    ......... a torch ....... Keep the candle burning
  8. Puppage
    Puppage Road Train Member
    4,264
    7,373
    Aug 2, 2012
    Connecticut
    Never....never use hot water in the lock.
  9. Vilhiem
    3,992
    10,904
    Oct 6, 2014
    Ive used it once in my pv when ice froze OVER the lock. Wasn't positive if the op was having the same issue.
    I would never use water inside a lock though, no. Should've clarified that.
  10. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    heat key w lighter insert/wiggle..reheat key w lighter insert/wiggle. etcetc
    Don't overheat key,alot of plastic parts n there..
    DoneYourWay and blairandgretchen Thank this.
  11. 201
    201 Road Train Member
    12,337
    25,223
    Apr 16, 2014
    high plains colorado
    Hi RERM, it's a pain once they are frozen, but once you do get it unstuck, WD-40 is the best bet. It displaces moisture for the next time.
    Menehune, Starboyjim, RERM and 3 others Thank this.
