Frustrated
Discussion in 'Peterbilt Forum' started by pat60tx, Nov 9, 2013.
  1. pat60tx
    pat60tx Bobtail Member
    5
    Nov 9, 2013
    I've a 2012 Pete garbage truck with Cummins PX8 and allison automatic. Truck runs fine and then just dies. No codes no warning lights no nothing. Turn the key off, then back on and it runs fine. I can't find any visible harness issues.
    freightliner438 Thanks this.
  3. wolfen
    wolfen Bobtail Member
    29
    6
    Jan 23, 2010
    Dalton GA
    sounds like it might be a relay getting hot. causeing the shut down. how long do you wait before restarting the truck??
    CondoCruiser Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It sounds like trash in the tank. No pun intended! :)
  5. kenszo47
    kenszo47 Light Load Member
    55
    17
    May 21, 2012
    DELAND,FL
    jWhat does the diagnostic computer readout tell you? Outta the thin air,,i'll weigh in with saying its a clogged exhaust filter.
  6. pat60tx
    5
    Nov 9, 2013
    The diagnostic computer doesn't read any trouble codes at all. Nothing.
    Thanks!
  7. pat60tx
    5
    Nov 9, 2013
    I take it you are meaning crap in the fuel tank??
    Thanks!
  8. tow614
    tow614 Road Train Member
    3,759
    4,630
    Mar 18, 2013
    Had same problems with a volvo.. same engine and tranny... it was wiring harness shorting out...had to replace it about once a year..
  9. pat60tx
    5
    Nov 9, 2013
    Engine harness was my thoughts as well. The whole electrical system shuts down like you turned the disconnect off.
    Thanks!
  10. pat60tx
    5
    Nov 9, 2013
    30 seconds to a minute. Thanks!
  11. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    18 years as a mechanic for WM. All depends on the body maker for this, but is it a Universal, Labre, Etc? Some builders installed home made tanks at the factory. When it stalls, open your fuel tank cap. If you hear air suck in, the breather is plugged or none existent. After a few hours of sucking fuel, the tank creates a vaccumn and wont let fuel into the engine. Try leaving your cap loose and see.
