Has anyone used the Amsoil: Diesel Concentrate Plus Cold Flow Improver ? I was wondering how good of a product it is, or if there is anything better out there. We are gonna have some more bad weather, and I'd like to make sure the fuel and the truck is good to go for the low temps. Thanks
Fuel Additive for winter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Vampire, Nov 2, 2012.
Page 1 of 6
Howe's works fine for anti gell purposes and is reasonably priced. I use that and haven't had any problems right down to minus 40 degrees . Put a water removing additive through the tanks as well as you can get condensation over summer and that will cause issues in cold temps. I haven't used the product you're describing but if it's more expensive than howe's then just save the money and use howe's.
I used it for a couple of years and grew kinda fond of it. I run primarily in the upper midwest all year round. I have had issues with other brands off and on, but the Amsoil product did a great job. Especially with so many outlets now having some level of biodiesel in their fuel. I am subjecting myself to a guinea pig test on a different product this winter. XLP Diesel Additive. It is made in Olathe, KS under control of Chevron. The product is marketed thru Amway. I have a friend, whose son is a dealer and wanted me to try it. The data on it shows almost identical properties as the Amsoil stuff, but is a lot more cost effective, as the application rate is lower. You might want to take a look at it yourself and compare. If you use the Amsoil stuff, get it on a Preferred Customer or Commercial account so that cost is a lot lower than list price.
Here is the info on the XLP stuff I am trying......
http://www.quixtar.com/Documents/IWOV/vis/010-en/pdf/ShopBuy/XLP_Diesel_SellSheetV08.pdf
Both the Amsoil stuff and XLP seem to address not only general fuel gelling, but cold filter plug point and anti-icing. There has always been some level of water in fuel, but ULSD seems to really be prone to higher levels of water nowadays. The anti-icing addresses that. And fuel stability is becoming more of a problem. Again, these two products target that also. I was a little hesitant to move away from the Amsoil product, and if the XLP doesn't perform well, then I will go back to it. Only after looking over the data on XLP and seeing it was pretty close to the Amsoil product, and more cost effective, did I decide to try it out. -
70% diesel and 30% kerosene works well also.
Most fuel additives can be expensive, just saying. -
Get your Howes at a farm supply store... 2/3's the price of what you find at the truckstop.
kw9's rock and bullhaulerswife Thank this. -
Howes is a good product. I used it for several years. But after a couple of instances of icing problems, I decided it was time for something else. ULSD was the big factor in that. Could be Howes has modified their formula in the last couple of years to handle that better. Howes always did an exceptional job handing fuel gelling. But it did not handle icing well for me. You have to look at application rate along with the cost. Lets take a look at what you mention getting Howes for.....
$15 for 1/2 gallon, or $30 for 1 gallon. Compare that to $57 for a gallon of XLP, but the XLP treats 600 gallons of diesel, lowers cold filter plug point 35 degrees and prevents icing to -50F. Howes treats only half that much fuel at the below 32F suggested applicaton rate, doesn't even mention how much it reduces cold filter plug point (more critical than gel point, since it will happen before fuel actually gels) or how low it prevents icing. Run the numbers on application cost per gallon of diesel and see which one comes out better. If they are the same cost, then determine which product does a better job. The Amsoil product falls in between Howes and XLP for cost per gallon application. -
I've only had my davco ice up once and I already knew the filter needed changed. I use Howes and always fuel with Philips 66 fuel. If it's getting -40 with the wind blowing the truck idles all night. I've seen guys run the pull-up diapers on they're davco to insulate it if the wind chill is low.
Had one of the old boys say they always ran a gallon of unleaded on top of there tanks after filling. Don't know if that would help with the new fuel. -
Page 1 of 6
