Fuel and oil filters, what brand for your engine?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Dec 28, 2021.
  1. Oxbow
    Oxbow Road Train Member
    13,317
    137,939
    Nov 24, 2015
    Stupid. Me too, except for the Rotella part. But I don't have anything bad to say about Rotella.
    singlescrewshaker and Last Call Thank this.
  3. MacLean
    MacLean Road Train Member
    1,360
    4,008
    Sep 12, 2017
    Fleetgard or Baldwin and Rotella oil always.
  4. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
  5. dchawk81
    dchawk81 Light Load Member
    182
    408
    Feb 5, 2017
    Fleetgard here. No reason other than it's what the truck has seen all its life, and the carrier I bought the truck from sells them to me at or near cost.
    I do the same with oil. They did the changes for the first 400k so I'm letting them keep doing it.
  6. MacLean
    1,360
    4,008
    Sep 12, 2017
    Advanced Filtration Systems Inc., located in Champaign, was established in 1986 as a joint venture between Caterpillar Inc. and Donaldson Co. AFSI designs and manufactures high-efficiency fluid filters used in Caterpillar machinery worldwide.
    You can’t go wrong with Donaldson.
    Pamela1990 and mile marker 27 Thank this.
  7. Oxbow
    13,317
    137,939
    Nov 24, 2015
    You have me thinking now; last fall we changed out filters on one of our excavators because the fuel restriction light came on. We did not have Cat filters on hand grabbed some Napa filters to get by. After a day or so of running the hoe started intermittently losing rpm running poorly. I thought we would have to have a tech come out and diagnose the problem but decided to change out the filters back to Cat just to eliminate that possibility. Sure enough that's all it was. I hadn't thought about the filters failing, just thought we had the wrong filters - until now.
  8. Pamela1990
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    The Awakening.
    singlescrewshaker and Oxbow Thank this.
  9. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Is it possible to cross reference part numbers and put Cat filters on? I know some may think it's sacrilegious, but Cat does have a good reputation.
  10. Oxbow
    13,317
    137,939
    Nov 24, 2015
    It should be as it works the other way around (non-oem to cat). I just googled Cat fuel filter cross reference, and there are tons of charts to browse through.
    singlescrewshaker and Pamela1990 Thank this.
