Fuel filter housing on Century with ISX pre EGR
Discussion in 'Freightliner Forum' started by CellNet, Oct 12, 2019.
  1. CellNet
    CellNet Light Load Member
    203
    82
    Jun 19, 2011
    Chicago IL
    Hello, do you guys have an idea why on my Century with Pre EGR ISX has a fuel filter housing that has only empty can for a fuel filter. So basically now I have only Davco water separator as a fuel filter. Why is like that, can I add a normal fuel filter?
  3. CellNet
    203
    82
    Jun 19, 2011
    Chicago IL
    Anybody with ideas?
  4. QUALITYTRUCK
    1,780
    1,726
    Jun 14, 2009
    romulus,mi
    Cummins had an issue when they introduced the ISX 570. Fuel pump had trouble drawing fuel from tank on start up. They figured it out and the fix was to add electric priming pump. You can try removing cap and adding filter (FF2200). I have not tried it. Maybe the Davco will hold enough prime to start truck. Report back with your findings.
    CellNet Thanks this.
