Fuel Guage not working has power 2010 peterbilt 387
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Apr 22, 2014.
  1. Big Lou
    Big Lou Light Load Member
    155
    25
    Aug 15, 2013
    Tampa, Florida
    had my truck washedand tanks brush afterwards I noticed that my fuel gauge was not working can't seem to find a wire or something that would do that there is.It has power we.'r the gaugeseems like the needle is just stuc on E completely not working
  3. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    You have a wire loose its gonna be on the top back side of your fuel tank. If you got all that fiberglass junk covering your tanks its gonna be hard to get at. You will have to get to it from up under your truck.
  4. Powder Joints
    7,732
    7,873
    Sep 25, 2007
    Rosamond, SoCal
    Check the plugs at the tanks first, clean and replace. Check the sender with a ohm meter, call Peterbilt for the impedance spec.you can also check the gauge the same way by asking for the impedance.
  5. danezu
    danezu Bobtail Member
    6
    Apr 22, 2014
    You might have water in the fuel level sending unit plug; unplug un dry it out.
  6. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Fuel sending unit is usually the culprit here. As stated before, check the wiring at the plug, then check resistance on the sender itself. Not a terribly difficult fix to replace the sending unit if that is the problem (which it most likely is), although on our KWs you have to loosen the tank straps, loosen the fuel lines, then rotate the tanks to change it out.. that in itself isn't such a daunting task, although it is a bit of a PItA.
