Fuel In radiator? Can diesel get into the coolant system?
Discussion in 'Freightliner Forum' started by jsnell, Oct 26, 2017.
  1. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Thank you QUALITYTRUCKS. It is in a shop and two mechanics said they think the antifreeze is mixed different kinds. I think it is diesel. The truck is good in every other way and will pass a Landstar inspection. But this scares me. Thank you all for your input.
    CleverNDGuy Thanks this.
  3. CleverNDGuy
    CleverNDGuy Light Load Member
    64
    92
    Jan 25, 2016
    Bakken Basin
    Had that problem in mid September. Good luck.
    jsnell Thanks this.
  4. aussiejosh
    aussiejosh Road Train Member
    4,759
    5,561
    Aug 28, 2009
    Airlie Beach QLd
    Not unless someone deliberately opened the fuel tank and poured it in!
  5. jsnell
    253
    343
    Apr 12, 2016
    Lot had 5 of these from the same fleet. 4 had clear bad smelling stuff in fill tank. They said it was from mixing red and green antifreeze. I passed on that truck.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    it's a diesel. I agree with QUALITYTRUCKS .I had two 14l s60 before. common problem on 14l dd s60.
    jsnell Thanks this.
  7. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    had this happen bout a week ago on a c13, its your injector seals and copper seals, those need to be replaced, also drain and replace your coolant, and then replace it again after two trips to get everything cleaned properly, your looking at some possible head damage if it isnt fixed in time
    jsnell Thanks this.
  8. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Empty the fill tank into a jar of water. If it floats,it's diesel.
    jsnell Thanks this.
