Fuel Mileage on MXS C15 cat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mark2842, Feb 25, 2014.
  1. mark2842
    mark2842 Light Load Member
    104
    15
    Nov 10, 2007
    Lawrenceville,Ga
    The question I have is. This is in a 2007 w900l kenworth, When we installed the PTO for the blower install we detoured the exhaust to one muffler to make room for the PTO. Will this cause or effect the fuel mileage to go to crap? Truck specs are 475hp 13spd trans, 334 rears. Pull a pneumatic trailer in the oil field. Grossing 80,000 lbs plus most the time.
    Thanks for all input
    Mark
  3. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    Good luck with mpg. It will fall rapidly. When I bought my t600 with mbn c-15 it was 5.49 mpg as of 2011. Right now it is 5.19 mpg. It also has pto blower, hauling the same gross weight like yours, and drive in to natural gas wells mountains of PA. Pulls excellent in hills/mountains with eaton 3.70 rear, eaton 10 sp manual, and 500 hp 1850lb/ft. Yours has 18 sp and 3.36 rears, I think you will have better mpg than mine for now on.
  4. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    My truck W900 MXS 475hp 13speed 325 rears on LP22.5 does good on hwy but local work sucks I'm getting 3mpg but over the road it gets in the 7s and my truck don't pull good at all hills kill me
  5. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Bayou is that an App?
  6. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    It's available on computers letstruck.com
    Can downloaded as an iPhone app.
    morehp Thanks this.
  7. BAYOU
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    And it's free...it also tracks my fuel in each state I love it!!
    morehp Thanks this.
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    The Acert 475Hp and higher Hp engines with an 1850 torque output rating require two 10" diameter mufflers to reduce exhaust restrictions through the catalytic converters or a single muffler that is 14" in diameter. By modifying the dual muffler exhaust to use only one of the existing mufflers is going to cause major exhaust back pressure issues at full power output of the engine. I'm assuming that you have the muffler mounted under the truck. Remove it or the only muffler that I've seen that you can replace it with is a Pittsburgh Power muffler designed for the 2002 and earlier KW W900L AeroCab sleeper trucks. You need to get rid of the catalytic converter muffler no matter what you do, otherwise fuel mileage will suffer greatly with the current set up.
    The twin turbos kills a lot of exhaust sound, so running straight pipes isn't as much of an issue with noise as the older trucks were. They still have a fairly noisy jake on straight pipes though.
    I've got a customer in Texas with a modified MBN that does this type of work that is getting great fuel mileage pulling a pneumatic trailer, but he does have an APU for his waiting to unload at the well head.
    mark2842 Thanks this.
  9. mark2842
    104
    15
    Nov 10, 2007
    Lawrenceville,Ga
    I called Pittsburgh power and told him what I was wanting and said they couldnt sell me that muffler for a acert engine. Said if had a different application no problem. So Im doing more research.. Thank You Mr Haney, I was waiting for a reply from you. Ill try and get one put on.
    Mark
  10. morehp
    699
    206
    Jun 18, 2012
    If Any ones interested I've found another I phone app that does fuel and maintenance / repairs. I think its a good idea to keep track of running costs.
  11. morehp
    699
    206
    Jun 18, 2012
    Kurt
    I'm sure you have heard that in ozz the NXS in the new cat trucks are coming out with twin dpf, that has to choke them up, there are a few getting around here now but I haven't realy heard any fuel economy feedback about them.
    They are more of a catalytic muffler than dpf I believe as there is no fuel dose to burn,
    Looking into my crystal ball I see people removing them in the future.😜
