Hey yall, Im new to the forum and also to trucking as well. I purchased a 1998 W900 with the 3406e. I've worked out most of the bugs on the truck to get her road ready but this same problem keeps coming back. The passenger tank drains completely and fills the left tank up. I've replaces the vents, lines, return equalizer valve, and I've flushed each line. I have also emptied and flushed out the driver tank thinking maybe trash has been blocking the pickup tube, but it has not. The line from the tank to the water separator is clear, Ive blown it out with air. I'm at a complete loss on what to do. The last thing I can replace is the T fitting for the suction but it is just a simple fitting. Any ideas, comments? I've been racking my brain trying to figure out what else to do. As I said, this is my first truck and hopefully soon I'll get my authority but if I can't fix this problem then I'm dead in the water. Thanks yall and have a blessed day!
Fuel only from right tank
Discussion in 'Kenworth Forum' started by Harper60, Jan 9, 2017.
The return lines from the T to the tanks have to be exactly the same length. If they're not it will act weird like that. That's the only thing I can think that you might try.
The lines need to be a mirror image,if you have a droop on one side you need it on the other. If you have shut off valves in the return lines you can partially close one to force fuel to the tank that's running dry.
Thanks guys, I also didn't mention that it doesn't pull fuel from the driver it seems like. It returns the fuel correctly to both tanks
Which is what I do anyway -
I actually just purchased ball valves for the suction and returns, I guess if it works then I'll be happy for now, i may run a equalizer line underneath like the old school trucks if this doesn't make me happy, thanks yall! I'll update if I find anything new
So I put a ball valve on the driver return line and closed it off and I watched the field gauge go from half a tank to a quarter tank on the driver side in about 10 minutes so its pulling from both thanks equally it's just not returning equally. I had a local shop install the lines and I look to be identical and link so I guess all that is left is to put an equal icing line from one to the other. I'm not really happy about doing this because it's built to work with the stuff that has right now and putting this line on means that it's not working properly and I am a man who likes things to work that way they were designed to work haha, thanks to those who helped, I look forward to being a member on this site!
HopeOverMope Thanks this. -
You can put each return line in a bucket and run the truck a bit. If they're both about equal then it's in the tank.
I had this happen on a Ford LTL 9000 once and it was just a small cheap part....a small cast part with some rubber diaphragms.
I'd check the vents on the fuel tank caps.
