Fuel pressure gage used to read, 75psi, now read less then 10, truck runs good
Discussion in 'Peterbilt Forum' started by Mr. Cob, Sep 25, 2023.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    I use my 2001 379, to tow my large RV trailer so it doesn't get used often but covers many miles in a short time when it is used. I start the truck and let it run for a half hour once a month, the last time I had it running the fuel pressure gage read as it has for the last 50,000 miles that I have owned the truck the needle twitched and held a steady 75 psi. Today when I started the truck the fuel pressure gage read less then 10 psi and moved a few psi when I reved the engine from idle ( 750 rpm ) to 1,500 rpm. The engine seems to be running just fine but it's NOT under a load. Where do you folks suggest that I start looking to see if I have a problem that needs to be corrected before I leave to go south for the winter. I don't want to be stranded on the road so any advice will be greatly appreciated. THANKS.
    Dave
  3. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Verify the gauge is accurate would be the first thing.
    Big Road Skateboard and Mr. Cob Thank this.
  4. Mr. Cob
    Howdy Lyle,
    That was my first though but as I don't have a spare gage and don't want to spend 150 bucks an hour unless I have too I was hoping someone would have a different suggestion on what might cause this problem "IF" the gage is reading correctly. Thanks for your reply.
    Dave
  5. Lyle H
    1,291
    2,937
    Apr 16, 2014
    Well, you could try changing the fuel filters and see if that makes a difference. If nothing else, take it for a drive, and see how it acts.
    Mr. Cob Thanks this.
  6. 062
    062 Road Train Member
    6,232
    33,516
    Oct 20, 2013
    You may have a reed valve in line to prevent fluttering. It may have a piece of trash in it.
    @wore out may have some more ideas.
  7. wore out
    wore out Numbered Classic
    16,073
    194,656
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A C15 won’t run on 10 psi fuel pressure. There is a damper somewhere to keep the guage from bouncing odds are there is your issue. If you want you can get a compucheck fitting and another gauge put them together and check the pressure with a different guage at the filter base. Starting as usual sounding as usual your fine I’d say
    Luwi67, Mr. Cob and 062 Thank this.
  8. Mr. Cob
    Howdy Lyle,
    Just checked my records I am due for an oil and filter change so I will give that a try before I get all worked up. Because the truck sits for months at a time I am sure crud gets in the fuel tanks, the last time I changed fuel filters the first filter had a bunch of gray slime on the top of it when I took it off the frame mount, the fuel filter on the engine didn't have that gray crud.
    Dave
  9. Mr. Cob
    Howdy 062,
    I am not familiar with a "reed valve" in the fuel system. I built this truck going on 6 years ago, the fuel pressure gage has always fluttered/twitched a bit at 75 psi. Do you know if this is located someplace a person can get at it, take it out and clean it? Thanks for any other information you can share.
    Dave
  10. Mr. Cob
    Howdy wore out,
    I kinda figured it would need more pressure then 10 psi to run correctly, which leads me to suspect either the gage or as 062, suggested something in the fuel line that's causing a low reading. I will do some more research and see if I can just disconnect some lines and blow them out with air. When we go south we usually go down through Nevada on Hwy 93, many miles of high desolate country very bad place to have problems or break down, in the summer let alone the early part of December when we will be traveling.
    Dave.
    Oxbow and wore out Thank this.
  11. 062
    6,232
    33,516
    Oct 20, 2013
    Generally it’s at the back of the gauge. It’ll look like a union or adapter.
    Mr. Cob, Oxbow and wore out Thank this.
