fuel pressure gauge bouncing
Discussion in 'Peterbilt Forum' started by beemergary, Apr 12, 2015.
  1. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Took my playtoy with a 3406b for a ride today. The new gauge always bounced alittle @ 40#. Today was going crazy between10-50. Was waiting for the needle too fly off. Does it need to be bled or something. Thought I'd ask before calling Autometer. Thanks
  3. Ridgeline
    22,124
    113,382
    It needs a damper on the gauge, you can make one with a needle valve put in line between the isolator and gauge.
  4. Epmtrucks
    Epmtrucks Medium Load Member
    319
    182
    Mar 31, 2013
    Change the fuel filter and see what happens. Is it spoiling up normally?
  5. beemergary
    229
    112
    Apr 11, 2014
    Its a mechanical gauge. Truck runs fine. The needle bounces so fast its a blurr.
  6. Epmtrucks
    319
    182
    Mar 31, 2013
    I ran a 7fb 350 and now a 4ck 460 and changing filters seemed to help. I run high efficent filters and they seem to restrict fuel flow after 1200 to 1300 gallons. It caused fluctuations in fuel pressure and tubo boost.
  7. beemergary
    229
    112
    Apr 11, 2014
    Only around 300 gals. run threw Cat filter. Was ok when left home . Needle turned into blurr after 40 mi. Gauge is newer than filter.
  8. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Take the hose off the back of the gauge and put a pipe cleaner in the hose, worked for me.
  9. beemergary
    229
    112
    Apr 11, 2014
    Took Advise-gauge 90% better now. Yaa Woo
