Fuel rail sensor location C-15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by xcavater, Sep 22, 2011.
  1. xcavater
    xcavater Bobtail Member
    Baltimore,MD
    I have a CEL on a Cat C-15 MXS engine. I used a Cummins Quickcheck ( it's what we have in the shop) and it is saying Injector Metering Rail #2 pressure- voltage above normal or shorted high.
    Where is the sensor located?
    Thanks
  3. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    they dont have a fuel rail sensor. Fuel pressure sensor was optional. the vva pressure sensor are known for going out and they are up front of the engine right side of the valve cover base. That software isnt giving you the correct fault codes.
    xcavater Thanks this.
  4. xcavater
    Baltimore,MD
    Thanks, I'll have to get it into CAT.
