Fuel tank leak ?
Discussion in 'Ask An Owner Operator' started by 2hellandback, Apr 30, 2008.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    I have a very small leak in the bottom of my tank maybe a pint per month but id like to fix it, any quick easy fix ideas ?
    Im thinking that 2 part epoxy clay like stuff they have!
    Would appreciate any ideas?
    Thanks!
  3. broncrider
    broncrider Road Train Member
    napa has a 2 part epoxy, with soap stick, sand paper and cloth....costs about $12
    mine dont leak no more....LOL
  4. Coastal Transport
    Coastal Transport Bobtail Member
    11
    In the Sleeper
    Use Some JB Weld found at any auto part store.
  5. truckinpa16
    truckinpa16 Light Load Member
    66
    Apr 27, 2007
    rochester ny
    they have a puddy at TA that you mold with your hand for like 15 minutes then put it over the whole and stretch it out then it will harden and be mint. Or that two part epoxy from napa is just as efective
  6. 2hellandback
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    I tried that 2 part epoxy clay stuff and it would not even begin two stick, ended up using some old JB weld i had,so far its working.
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    I had an old Escort that had a leak on the tank sender plate where the high pressure line came out—the line was rusted and almost broken off. You couldn't buy just the tank adapter, it came with the fuel pump, sender and filter—$278 for the assembly! I was not about to spend $278 on a $300 car.
    JB Weld to the rescue... I used the putty to support the tube where it came out of the plate and then coated it with the two-part liquid because the putty was still a little too porous to hold back the high pressure fuel (it was seeping just a tiny bit).
    Two years later, this repair was still holding and not leaking in the slightest when I sold the car. I'm a believer now... the stuff works.
  8. animal control
    animal control Medium Load Member
    307
    12
    Aug 7, 2007
    Where I come From
    Also worth mention woud be to use wrenches on the crossover/pickup/return line or whatever.
