Fuel tank not equalizing while I'm driving
Discussion in 'Experienced Truckers' Advice' started by Alex2019, Nov 11, 2022.
  1. Alex2019
    Alex2019 Bobtail Member
    Kansas city
    I have 2019 frightliner having issue with fuel equalizing fuel coming from passenger side tank into driver side while I'm driving and it makes air pressure in the driver side my truck doesn't have the shut off valve and crossover line to level the fuel tank changed the breathers on both tanks that doesn't work truck is at local mechanic shop he doesn't know what the exact problem is
  3. wichris
    wichris Road Train Member
    4,314
    8,679
    Jan 17, 2011
  4. RockinChair
    RockinChair Road Train Member
    5,116
    12,935
    Feb 19, 2012
    CC, TX
    If you have vented fuel tank caps make sure they're not plugged up with crud.
    tscottme Thanks this.
  5. Stringb8n
    Stringb8n Road Train Member
    1,628
    2,094
    Sep 27, 2015
    Do you have locking caps, or a chain attached to the cap to keep it with the tank when you are fueling? If so, might check to see if either the lock tab came off into the tank or the chain went into the tank.
  6. tscottme
    tscottme Road Train Member
    I had that issue with a Volvo. It only fed from the driver-side, for example, and the return fuel only filled the passenger-side. I don't recall the fix. I'm a company driver, I just ask for another truck.
  7. striker
    striker Road Train Member
    6,023
    6,438
    Aug 8, 2009
    Denver, Co
    Intermittently having this issue my T680, on mine there are small hoses coming off the breathers, both of those appeared to be clogged, once I cleaned them out, it took a couple days but the tanks started to equalize again
