fuel temp sensor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigswede, Mar 5, 2009.
  1. bigswede
    bigswede Light Load Member
    50
    Dec 6, 2008
    has anyone had problems with fuel temp sensors on cat engines,it is the sensor by the primary fuel filter?
  3. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    I had my truck at Cat couple of months back for a turbo code, also found a fuel sensor code. They replaced the sensor, and code was removed.
  4. Bigstretch
    Bigstretch Light Load Member
    161
    30
    Jun 14, 2008
    NW IL
    Mine is working fine. :D
  5. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I haven't had a lick of problem with my fuel temp sensor...so far. The sensor is on top of the filter bases that is mounted to the motor. You can't miss it.
