Fueling strategies to lower fuel costs
Discussion in 'Questions From New Drivers' started by cpieren, Jan 3, 2014.
  1. cpieren
    cpieren Bobtail Member
    8
    5
    Jan 3, 2014
    My husband recently started driving long haul, and he's doing a lease program. We are looking at ways to manage fuel costs other than the obvious watch your speed, maintain tire pressure etc. I was just wondering if most people fill their fuel tanks completely each time they fuel or just fill enough fuel to make it in between cheapest fuel stations (with some cushion of course). What are some of your fueling strategies to keep fuel costs down?
  3. Highway101
    Highway101 Road Train Member
    1,145
    693
    Sep 19, 2011
    Fallon, Nevada
    Shift points, over reving the engine will use fuel, also knowing the cheapest fuel stops in advance. Fuel taxes, watch them also. Do not idle the engine.
    cpieren Thanks this.
  4. Ridgeline
    22,385
    116,240
    OK first thing to learn is this - how states charge fuel taxes and what these taxes are. With that knowledge, you can plan on your fuel purchases to save you either money at the pump or through the tax savings or both.
    I would always fill up, no matter what.
    cpieren and wore out Thank this.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I look online & check all fuel prices on the route that I will be on, before I leave out. then I pick which one I want to stop at. I always fill up so I can keep tabs on my m.p.g. if it falls I will know in the next fill up.I calculate at every fill. when it starts to drop off, other than cold weather, hills, wind, e.t.c. I make sure air flit is not over due, overhead is not needed, check tires e.t.c. when I was o.t.r. I would do everything at one stop. fuel, shower,sleep, eat. I never idled. even at the fuel island. even when cold out unless extreme cold. would idle for 15 min, heat on get truck nice & warm then turn off. usually wake up in 4-5 hours start truck let run for 30 min or so & shut back off. these were just my habits good or bad. leaving early so I could cruise at 62 m.p.h. saved me $375.00 a week doing 2 runs to g.r. MI & back home. at that time was as follows. 1700 miles round trip x's $3.00 a gal. the diffrence in driving 62 vs my other speeds of 68-72 m.p.h. was 1 m.p.g. & $375.00 in saved fuel cost. but it cost me in time, but that was .o.k.
    cpieren and Jokingypsy Thank this.
  6. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    I practiced the latter, but in those days you could put on 50 (or 75?) gallons and just flag it w/o taking 15 minutes, so it was even more attractive. You can take that technique almost as far as you want, grinding down the numbers to the gnat's behind.
    You can also practice managing your momentum better/smoother than your speed control. It's hard to beat on the flats, but in hilly terrain it wastes fuel to carry speed over the crest of a grade, then sometimes accelerate down the other side. Use gravity, works every time.
    I like to drive as if I have no brakes, and use them like I don't like to. Creating and maintaining following distances is crucial to avoid braking. This usually requires being the slowest vehicle on the road (which usually only requires observing the speed limit), so the nuts who are going to use your LF fender as a pylon no matter what have plenty of room to pull away, and you have plenty of space to avoid them if they crash. Few drivers have the discipline to take it to that level.
    double yellow and cpieren Thank this.
  7. amiller
    amiller Medium Load Member
    475
    249
    Nov 26, 2012
    Charlotte, NC
    One small tip is to not "top off". When the nozzle clicks hang it up or you'll be paying for fuel that may return back to the pump
  8. 6 Speed
    6 Speed Heavy Load Member
    945
    482
    Jan 2, 2014
    I bought cheap fuel in SC for a couple months and then they got me on the IFTA tax,so they get you either way.
    CenutryClass and cpieren Thank this.
  9. TripleSix
    129,700
    cart.horse
    Dinomite and Joetro Thank this.
  10. Dinomite
    Dinomite Road Train Member
    4,092
    4,308
    Sep 6, 2012
    Looking 4 Rocks
    My strategy is not sign up for a lease purchase so some company can have me paying for that crap. Wind, Cold, and heavy loads all play a factor in fuel mileage. So if you truly want to save money get a few more years experience b4 you sign up for a fleece purchase.
    HalpinUout and TripleSix Thank this.
  11. TripleSix
    129,700
    Agreed. There are certain things you should learn on someone else's dime.
    Dinomite Thanks this.
