98 kenworth w9 n14 cummins full overhaul or partial
Discussion in 'Kenworth Forum' started by irishluck09, Jun 16, 2025.
  1. irishluck09
    irishluck09 Light Load Member
    271
    140
    Nov 24, 2019
    Had an issue with the motor burning a bunch of oil. Found oil in the #6 exhaust port. Torn down the top end to which we found the head gasket was leaking and a bent valve. Heads have been completely gone through, new valve, decked, etc.
    My question is should I just do the full overhaul? Nothing on the lower end is bad, pistons look good, sleeves are fine ect.
  3. Lazer
    Lazer Road Train Member
    1,829
    2,939
    Jan 22, 2017
    If the rest of the engine is up to snuff, put it back together with what you have, you should be good to go.
  4. Ruthless
    Ruthless Road Train Member
    9,094
    90,198
    Aug 28, 2010
    The City.
    You wanna do it right, or you wanna do it twice?
    Vampire, Feedman, Sons Hero and 2 others Thank this.
  5. SmallPackage
    5,675
    18,149
    Dec 20, 2019
    Marion Texas
    Many upon many Cummins have gone years and miles with just one head being serviced or replaced. There is a reason why they were originally designed with 3 individual removable heads like that.
    Opendeckin and Feedman Thank this.
  6. Sons Hero
    Sons Hero Road Train Member
    2,752
    27,874
    Jan 8, 2021
    Indiana
    I went cheap on an OH once. And the motor only lasted another 6600 miles, and we were back where we started. Didn’t make that mistake again. I’d do it right, not twice. Down time is irretrievable, and 2 shop bills will cost you more than 1. If you’re doing the work yourself, taking it apart twice will take longer than once too…….
    Vampire and Feedman Thank this.
  7. AModelCat
    161,362
    To put it into perspective if this was the late 90s or early 2000s and that engine was still under warranty Cummins would fix the damage and kick it out the door. If you wanted a full overhaul done at that time it'd be out of pocket minus what warranty covered.
    Vampire, Feedman and Sons Hero Thank this.
