fuller ultrashift transmission need advise
Discussion in 'Questions From New Drivers' started by saturnin15, May 8, 2014.
  1. saturnin15
    saturnin15 Bobtail Member
    i just pick up a 2009 international cumin engine with ultra shift transmission ,drove from Georgia to Indiana with 43000bl truck pull really nice no problem a few day they instal a TELETRAC device for log and communication with dipashe ,i pick up a load goind to viginia , i made it but on my way but to indiana teh nxt day the transmission stat doing bad it shift nice a couple gears and then stat revving without upshifting ,loosing speed on hill looklike it not shifting well any one on here have teletrac instal in truck with ultrashift transmission need advise im at the dealer now to what 's problem can it be the device ?
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    You may need parts changed to make it shift, box install may have robbed power from trans. ECM.
  4. 77fib77
    77fib77 Road Train Member
    10,478
    65,464
    Jul 7, 2010
    St Louis
    Check the power steering fluid. I drove a mack with an auto trans. Unless power steering fluid was above min it would hang up in a gear. I don't know why, but it did help. GrAnted it was a piss poor trucking company.
  5. Dieselgeek
    Dieselgeek Medium Load Member
    427
    209
    Nov 25, 2012
    Minnesota
    Sounds about normal for a useless shift… Everyday is different for the trucks I drive with them. Some days they work as they should, other days it can't figure it's way out of a parking spot.
  6. saturnin15
    thanks guy for your advise but international shop found out the problem is the clutch so i hope it will fix the problem after putting a new one
