Can anyone assist me in telling me where I can get a diagram on the International 9400i 2004 model? I have been searching the web to find it and can't locate anything.
My blower on Air Conditioner is not working properly and want to check the fuses first.
Thanks.
Fuse Box Diagaram
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigwayne, Jul 4, 2011.
Sorry fuse2 is same as fuse1 so here is a new pdf called fuse2.1 to replace it...
All blower systems are fused, have a relay, and a resister block. If the blower isn't bad it could be anyone of those. If the fan only works on one speed, then it's the resistor block.
Thank you so much. It is probably the resistor block. It doesn't work on 4 but does the rest so will go from there. Again my thanks.
Usually its the other way around with the resistor, the lower speeds will drop off but it failsafes to only work on high.
I could be wrong but I've had 3 go bad in cars and that's how they all failed.
Check for a bad relay also. -
I have a 9900.. 2000.. any reason that the only speakers working are in the windshield brow?? The others are there just not playing
Check your radio to see it the "fade" is adjustable which is controlling audio between front and rear speakers.
