Galaxie 959 question
Discussion in 'CB Radio Forum' started by chaindrive, Jul 3, 2009.
  1. chaindrive
    chaindrive Bobtail Member
    26
    Mar 29, 2009
    Shenandoah, IA.
    I recently aquired a 959, and I looked in manual for info about the "RF POWER" knob. I couldn't make sense of it, so I asked c.b. guy. I still don't get it!!! Why is there a RF GAIN and an RF POWER knob? The RF POWER knob doesn't seem to do anything. What is it for?! I sure like the radio though. It pulls in signals ALOT better than my Cobra 29 does.
  3. starman32
    starman32 Light Load Member
    54
    42
    Dec 4, 2007
    demorest,Ga
    The RF gain control is a control to reduce the signal strength of received signals.
    Typically it is left at full up , but when you are in an urban location with tons of strong signals they can overload the receiver causing distortion (fuzziness) in the speaker.
    In this case , turn down the RF gain control and it will sound better.
    Note ,the Rf gain control has NO affect on your output power.
  4. chaindrive
    26
    Mar 29, 2009
    Shenandoah, IA.
    I know what the rf GAIN is, but I don't know what the rf POWER is for. Sorry I didn't make myself clear! I've never had a radio with an rf POWER knob before. Thanks
  5. Sixx Burning Sky
    Sixx Burning Sky Light Load Member
    79
    14
    Aug 23, 2008
    The RF POWER is for you to adjust the deadkey setting on the GALAXY. It is an adjustment for the AM Carrier.
  6. chaindrive
    26
    Mar 29, 2009
    Shenandoah, IA.
    I see. Thank you very much! So does a LOWER set dead key strength sound better to other drivers than a higher setting? Thanks again.
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    The RF power is used to lower your deadkey so you can run a linear amp safely. Otherwise you'd have to pay a CB shop to drop your deadkey down when running an amp so you don't destroy the amp.
  8. Dodgem250
    Dodgem250 Light Load Member
    58
    14
    May 2, 2009
    Maryland
    RF Gain is a traditionally mis labeled control, it should be labeled RX Gain (for receive) , that would make more sense. The RF Power is the variable power output, "1" is low power and this can be set from 1 to 4 watts and then "10" is the power output on high, this can be set from 15-25 watts. Factory setting on the Galaxy 949 and 959 is 3 watts on ow and 4 watts on high. Of course the high and low power setting is something that I have to adjust on the inside of the radio.
  9. chaindrive
    26
    Mar 29, 2009
    Shenandoah, IA.
    Thanks a lot for the replies. That makes sense now! So It don't matter where I turn the knob, since I don't run a linear. :biggrin_255:
  10. Dodgem250
    58
    14
    May 2, 2009
    Maryland
    That's right, if you don't use a linear, run it on full 10.
