Galaxy 44 problem
Discussion in 'CB Radio Forum' started by yarddogmbw, Sep 24, 2011.
  1. yarddogmbw
    yarddogmbw Light Load Member
    94
    28
    Oct 16, 2010
    It seems like my radio is stuck between channels. Receive and transmit. Any suggestions would help.
  3. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    it sounds like it is probably a solder joint problem. it is a very cheap fix if you can take it to a technician that you can trust. that is one of the demons with a galaxy radio. one they are fixed, they are as good as new. i have had a few radios do this over the years, all of them were galaxy radios. the fix takes about an hour or so to run down and perform.
    what you can do is take the cover off and expose the circuitboard side. that is the cover without the speaker. take an insulated tool, such as a handle of a screwdriver, and with the radio on, slowly and firm, rub the handle against the board till you have done the entire board. i bet you will hear it pop back to life for an instant. this will not hurt the radio unless your pressing on the board like you are trying to punch holes in a steel wall so give it a shot.
    if you are uneasy about trying that test, just take it to a radio shop and have it repaired.
    yarddogmbw Thanks this.
  4. Happy_Hamer
    Happy_Hamer Light Load Member
    140
    40
    Aug 28, 2011
    Illinois
    I usually use a pencil upside down and press using the eraser, either will work,,,,,
  5. AB7IF
    AB7IF Light Load Member
    205
    103
    Jun 11, 2011
    Somewhere, Ar
    You must provide better symptoms if you want someone to diagnose it sight unseen. Does the RX/TX LED look off color like both colors are lit at once? If so you may have a 1 watt PNP transistor (2SA1282 or similar part) shorted or leaky, TR 36 or TR 38. A few other components in that circuit could be the cause but these two parts are what you should look at first.
  6. yarddogmbw
    94
    28
    Oct 16, 2010
    Thanks very much for the help. I will try these suggestions.
  7. yarddogmbw
    94
    28
    Oct 16, 2010
    Ok here is the update. Took radio to technician. I was told finals were out and he replaced them. radio worked good for two days. Now it is doing the same thing as before. Is something blowing the finals such as a short? Should I find someone else to work on this radio?
  8. boxcarmonument
    boxcarmonument Light Load Member
    70
    42
    Sep 22, 2011
    Canton Ohio
    A bad coax will fry your finals. Check your swr if they are too high that can burn your finals up.
  9. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Are you sure that the 10k switch is off?
