Galaxy DX 98 VHP 10 Meter Radio
Discussion in 'CB Radio Forum' started by BossOutlaw88, Jan 5, 2013.
  1. BossOutlaw88
    BossOutlaw88 Road Train Member
    1,451
    352
    Oct 30, 2011
    Cali
    I'm about to buy this CB from zcustomcbradios.com and I want to know if it's any good. I'm getting it peaked and tunes also. Anybody has any experience with this one?
    Sent from waterproof phone using Tapatalk 2 Blue
  3. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    They're a great radio if setup properly. I highly recommend buying it and getting it tuned from bellscb.com. He's awesome with those radios. Those radios swing about 250. Whatever you do, DO NOT RUN IT OFF OF A FACTORY ANTENNA!!!! I recommend running a Wilson 2000 trucker or a Wilson 5000 trucker.
    EZ Money and BossOutlaw88 Thank this.
  4. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    you will also have to wire that radio directly to the battery box with at least 8 gauge wire i do believe.
  5. EZ Money
    EZ Money Road Train Member
    Agree,
    I would want 6 gauge wire from the battery to feed that beast.Add about a 50 amp fuse inline.
    Bells is who is getting my new DX94HP ready,It is about 120 watts and they suggested 8 gauge wire to feed it and a 35 amp fuse at the battery.
    I looked a custom but his prices were higher and Bells does do great setups.
    Either way that should be a monster audio setup!
  6. BossOutlaw88
    1,451
    352
    Oct 30, 2011
    Cali
    I have a company truck and I can't hook it up directly to the batteries. Can't I just use the already wired factory CB terminals?
  7. BossOutlaw88
    1,451
    352
    Oct 30, 2011
    Cali
    You just saved me $200. Thanks.
  8. EZ Money
    No way! It will cook those wires! They are usually on a 5 to 10 amp fuse.
    From what i have read the 98 VHP will pull up to 40 amps.
    The first time you key the mic.....poof!
    You will need to wire it direct,run new coax and a good antenna.
    What make is the truck?
    Mine is a company truck also but i'm running the power off the battery,along the frame,through a rubber grommet that is already in the firewall,up the A-pillar and over to the upper console.
    So no need to drill any holes.
    Also most sleepers have rubber plugs in the bottom you could use to get it in the cab.
    I have 4 AWG run like that to my inverter.
    Did you end up ordering from Bells?
  9. BossOutlaw88
    1,451
    352
    Oct 30, 2011
    Cali
    It's a company Schneider truck. Freightliner Century. I think it's against company policy to wire anything to the battery.
  10. EZ Money
    Man,That sucks! No way that radio will run on those little factory wires!
    I would be asking your shop if you can do it as long as no holes are drilled.
    Also check your fuse panel inside the truck and see if a main power feed can be found there.
    BossOutlaw88 Thanks this.
  11. Voltrucker
    467
    133
    Sep 24, 2012
    West TN
    If he runs it off the fuse panel, his dash will light up like a Christmas tree. Run it and run it only directly to the battery. I think the op should've asked these questions before he ordered the radio. There's absolutely no way the prewired cb hookup will run that radio!
