Garman or Rand McNally?
Discussion in 'Questions From New Drivers' started by bamamac, Feb 20, 2016.
  1. bamamac
    bamamac Medium Load Member
    671
    282
    Nov 4, 2010
    Alabaster,Alabama
    Curious to know the biggest difference between the two.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,683
    18,457
    Nov 1, 2010
    Burnsville, MN
    Rand makes the best atlas, so it would make sense that they also have the best maps for GPS.
  4. taxihacker66
    taxihacker66 Road Train Member
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
  5. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I will agree that rand has better map data but I think garmin is better at making electronic devices. Read through the threads there are lots of complaints on the rands freezing up on a regular basis. I have a garmin and it has never froze up or not worked though a few times the routing it has provided has been a little goofy.
    It really boils down to a ford vs Chevy debate you find lots of people that swear by one or the other but the truth is they are both pretty decent. Me personally I can't stand it when electronic gadgets don't work properly so I chose a garmin.
  6. Moosetek13
    14,683
    18,457
    Nov 1, 2010
    Burnsville, MN
    I've had the 500, 510 and now a 520.
    It's true that they would lock up from time to time, especially if I worked it really hard. But that problem seems to have been solved a few updates ago.
    Now, nothing I put it through causes a freeze.
    And at any rate, if it did freeze all I had to do was reboot it.
    It was probably just a memory issue... trying to keep too much in RAM without clearing some out before making a new search.
    Like I said, it has been fixed.
    At least on my 520.
  7. Code Red NV
    Code Red NV Light Load Member
    54
    64
    Feb 11, 2016
    OK, dumb newbie question here: Are the company trucks fitted with GPS, or do you use your own?
  8. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    A combination of a map (paper or digital), a GPS and some intuition and common sense make for the most successful driver. If you try and rely on a single one of these, your experience might be less-than-ideal. Even a truck GPS doesn't know everything, so never rely on it. It'll get you into a serious jam.
    Moosetek13 Thanks this.
  9. Moosetek13
    14,683
    18,457
    Nov 1, 2010
    Burnsville, MN
    At Swift we have a GPS built in to the Qualcom.
    For the most part I never use it because it doesn't provide much useful information or ease of use.
    It is better than nothing, but not by much. I much prefer my RM 520.
  10. Moosetek13
    14,683
    18,457
    Nov 1, 2010
    Burnsville, MN
    Well said, and exactly right.
  11. Moose1958
    Moose1958 Road Train Member
    15,169
    33,411
    Dec 17, 2010
    Williesburg, Virignia
    I have owned both. I use a Garmin now. I won't waste my money on anything else.
