Garmin DEZL series IFTA reporting fault
Discussion in 'Ask An Owner Operator' started by RedForeman, Nov 16, 2014.
  1. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Posting here since this audience would be the most likely to even care about the IFTA reporting feature on a GPS.
    If you are using a Garmin DEZL series GPS to capture IFTA trip data, you need to check and see if that feature is working since the last updates. A pretty sure sign that it isn't would be that the IFTA icon in the settings menu is missing. That's the one you tap to get into the IFTA reporting features.
    When I pulled trip reports for Q3 around Oct 3, there were firmware and map updates. Pretty routine. New maps, firmware, and traffic databases come out every month or two. Like dozens of times before, I ran the updater and thought nothing of it.
    The only clue was that the option to edit the truck profile odometer reading on start up disappeared (I true mine up every week or so to keep the reports tracking with the actual truck odo). I thought, "great. some genius decided to fix a problem I don't have." Everything else worked fine, so nothing came of it. I never thought to check for missing icons, not that I would have noticed one missing if I did.
    Until today. My son's truck came down with engine cancer last month and it's replacement is hitting the road tomorrow. I had him in a rental last week that required trip reports to be turned in. No problem. He set up a new truck profile in the gps and kept on trucking. Except when I went to pull the report today, I can't. The IFTA button is missing. I browsed the memory on it and archived the gpx files. I loaded the current one in Base Camp, and the trip track displayed ok.
    There was a new map update available. After backing up those files, I installed version 2015-30 (new since at least Oct 3). The IFTA icon is now back, along with the option to edit the odometer reading on start up. The bad news is that no IFTA trip reports have been recorded since the previous software update. The tracks are there, but not the IFTA data.
    Now, since I have nothing better to waste time doing, I get to manually re-create trip reports for two trucks over a month and a half. At least I have the archived track data to work with, but really haven't found a slick way to use that to get state miles other than dropping waypoints on Google maps.
    This problem manifested on two separate 560's that were purchased a half a year apart (Mar 2011 and Nov 2011). If you're running the predecessor to 2015-30 on your Garmin, you may have the same issue. I'll follow up once I get back on the road and am able to verify it's tracking IFTA again.
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    When you change mode from truck to automobile IFTA logging is disabled. That's your problem
  4. RedForeman
    4,875
    22,141
    Jan 30, 2011
    No, it's not. On my son's gps, he set up a new truck profile called "Rental" and selected it. In truck mode. Auto, RV, or walking mode is never selected.
    Regardless, no IFTA trip data was recorded since Oct 3 on two separate devices that had been updated on the same day, and operated in the same correct mode that has produced the reports for 3+ years.
  5. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Strange. I have the same model and no problem. I check and update my device at least once a month also.
  6. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    Did your screen change at all? The top of mine turned blue and the speed limit is now in a red circle. My IFTA logging went away as well until I re-updated it (I use the IFTA logging for other things other than IFTA, useful nevertheless). Mine was only down a few days though. I had noticed on a trip to NC that NC did not exist in Garmin world, and neither did the rest of the Southeast.....
  7. RedForeman
    4,875
    22,141
    Jan 30, 2011
    I'm suspecting they probably released a bad update then silently put a fixed version out a few days, maybe a week later. If I was frequently plugging it in to check for updates, the impact may have been less than 1.5 months. But I don't. We have (not unlimited) mobile wifi on the trucks, so pulling down mega size updates while on the road is not done. When I get home, I have enough other things to catch up on than deal with gps updates. Had there been an email notification, I would have done an interim update as it's not a big deal to go in and manually do a trip or two.
    If we were entering fuel purchases in the gps, that could have been earlier warning that things weren't right. I wouldn't have been able to get to that screen at all. However, we don't do that since it's double work. I already get a fuel purchase summary from QuickBooks, so no need to do another one on the gps.
    Our gps units are 560's. There was no change in the map display. The only things that changed were:
    1. On start up, the truck profile is displayed, giving you an opportunity to review or edit the settings, or switch to a different truck or mode at that point. The only thing that changed was that the virtual odometer disappeared from that display, as well as the edit screen where you can make changes.
    2. The "IFTA Reporting" icon found in the top level tools menu vanished, leaving no path to reach the IFTA related functions, required to view them or export reports.
  8. RedForeman
    4,875
    22,141
    Jan 30, 2011
    Once or twice a year the background map on the display just vanishes in the middle of a trip. I'll look up and all that is displayed is the truck icon and the route, but no other features like local roads and whatnot. A restart fixes that. It only happens when I've left my gps on continuously for days. Shutting it down and disconnecting power at the end of the day forces a restart and seems to prevent that from happening.
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Just an FYI. You can customize the main screen to anything you want. You can also change the size of the icons. I have 15 icons on my main screen.
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I had the same problem when mine was updated. I noticed it the first day when I went to enter my fuel receipt.
