Purchased a new RGN trailer with a Honda pony motor in February.
Noticed gas was mixed with the motor oil. Flushed the cavity 3 times with fresh oil and refilled. All looked good.
Since, I have religiously closed gas supply switch and allowed the engine to stall out at the end of each use.
1 Month later, I open the dipstick, and oil and gas come pouring out.
Somehow the gas is getting to the oil probably when I'm driving down the road.
HELP PLEASE!!!!
Gas in oil of pony motor on RGN? How is this happening?
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, May 12, 2019.
Page 1 of 4
booley, Oxbow and Hegemeister Thank this.
This motor is brand new Feburary. The switch I close, feeds the carburetor, and I run it till it stalls. Frustrating.
Oxbow Thanks this. -
Take it back to the dealer you bought it from, best I can tell youOxbow and Hegemeister Thank this. -
Company I used to work at used small Hondas for pump motors... Half dozen to 10 trucks... Each year we would replace at least 3 pony motors.
Possibly a ruptured fuel pump diaphragm if it has one?kylefitzy Thanks this. -
I am guessing your Honda is a 13hp model GX390. If so they are notorious for the crank cases flooding when gas left on. You did say you cut the gas off and let the bowl run dry, but since it is still flooding the crank case with gas the fuel shutoff may not be shutting the fuel off 100% even when the lever is fully moved to the left (left is off and right is on). A way to check it is after you typically drain the bowl when running to wait for 10 minutes maybe and try starting it without turning the fuel back on. In my opinion though the way I would check it is to leave the lever off and then you remove the very bottom bolt on the bowl which removes the bowl completely and then see if it drips or runs with the gas shutoff. Turn the lever on and off and watch and see what happens. Just thinking it is a faulty fuel shutoff lever.
randyroadrage1969, okiedokie, catalinaflyer and 3 others Thank this. -
Hegemeister Thanks this.
Page 1 of 4
