Gas Tanker Throwing Sparks
Discussion in 'Questions To Truckers From The General Public' started by Bumble Bee, Feb 8, 2014.
  1. Bumble Bee
    Bumble Bee Bobtail Member
    33
    48
    Jun 2, 2007
    North Carolina
    A while back I came across a gas tanker on the Interstate that was throwing sparks from a chain that was dragging off its trailer. (It was night, so easy to notice.). Is this as dangerous a situation as it seems? What could I have done to get the driver's attention without him thinking I'm some kind of lunatic?
    Thanks!
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Not much..... Was probably a cap or dust cover both are usually chained to trailer. So they don't disappear ...
    Tanks are supposed to be vapor tight..... But who knows for sure..?
    Bumble Bee Thanks this.
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Or it was chains intentionally dragging on the ground for the sake of allowing static electricity buildup to discharge into the roadway. When you're hauling something as volatile as gasoline, that's sort of an issue to take into account.
  5. Dale thompson
    5,106
    42,315
    Nov 20, 2013
    commerce twp,mi
    that statement is so far off base not even funny everything on a fuel tank is aluminum so if something made of iron was dragging and sparking it was a BIG mistake
    Bumble Bee and WitchingHour Thank this.
  6. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I thought chains may have been a misnomer on the OPs part. Our AC and diesel tankers had a contact to the ground (although it wasn't an iron chain... looked more like the flat strips used for grounding out electrical systems in vehicles), plus we used these when unloading them. Somehow, I let the throwing sparks bit slip by me. But that's what I thought he might've been talking about. My mistake.
  7. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Lots of tankers drag metal behind. Not a chain. Mission Petroleum has them on all their fuel tankers in DFW area. Flat , somewhat flexible piece that contacts ground. Witching Hour was right on and very observant.
  8. Chinatown
    Chinatown Road Train Member
    73,381
    165,013
    Aug 28, 2011
    Henderson, NV & Orient
    Yep, it keeps static electricity from building up on the trailer.
  9. Bumble Bee
    33
    48
    Jun 2, 2007
    North Carolina
    Thanks for all the responses. I'm not convinced, however, that what I saw was normal operation for a tanker. It may or may not have been a chain, but it was most definitely sparks. I've been commuting to work on the interstate for over a decade and I live a few miles from a major gas distro center...but I've never before or since seen sparks thrown from a tanker like that.
    Chinatown Thanks this.
  10. Chinatown
    73,381
    165,013
    Aug 28, 2011
    I agree with you, I think he left a cap off or the chain to a cap had come loose and dragging.
  11. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,965
    9,559
    Oct 18, 2010
    NW Indiana
    A proper grounding strap, which hazmat tankers hauling flammable materials frequently use should be made of a woven conductor like copper that shouldn't spark. If it was a dragging fuel cap, it would be made of aluminum, no spark. There was something dragging and sparking that should not have been. There shouldn't be sparks coming from any vehicle much less a gasoline tanker.
