Gauges jumping up and down - electronic shortages at the dash board
Discussion in 'Freightliner Forum' started by dismag, Jul 20, 2012.
  1. dismag
    dismag Bobtail Member
    37
    Jul 20, 2012
    Some times tachometer, speedometer and gauges start jumping up and down. Shutdown engine then start again and problem disappear. One of my known mechanic said that it is the electronic shortages at the dash board. Just want to get some advices before start troubleshooting the dash board panel.
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Check and clean ALL your grounds!
    Check all electrical connections.
  4. Hardworker
    Hardworker Light Load Member
    113
    21
    Jun 27, 2012
    Minneapolis, MN
    1. Well I had this kind a problem after bein park few months i think may 4-5mos and the problem existd for about a weak and usualy it was happening when ever i hit little bump so i just clean up all the grounds and retide battery and cables and the starter cables too and the problem disappear oh also cleaned the ecm fuse back on the batterys.. m y truck 2003 columbia with MBE 4000.
  5. dismag
    37
    Jul 20, 2012
    where that backup battery located
  6. Hardworker
    113
    21
    Jun 27, 2012
    Minneapolis, MN
    Didnt say nothing about a backup battery, but if you are talking about the fuse. its usualy on top of the battery.you cant miss it.. but also check every thing in that area to be as it should be tide.
  7. dismag
    37
    Jul 20, 2012
    the batteries located in the back comportment behind the cab or you talking about other batteries?
