Gauges
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tmlonghorns, Apr 15, 2009.
  1. tmlonghorns
    tmlonghorns Light Load Member
    278
    43
    Mar 12, 2009
    Gregory, MI
    Before I get blasted.....this is my own truck and I have no experience and am not out on the road hauling stuff. I use this truck on my farm.
    I have a water gage that runs about 200 degrees. The last couple of times I have noticed the water engine gage flopping all over the place like a fish out of water. Sometimes it will get buried at 230 degrees. I also have a switch to turn on the fan. What fan I don't know but I assume it would be an engine fan. Should I be turning this fan switch on and what is the difference between the temp gage and the engine water gage?
  3. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    We might get a better idea to help with your problem if you tell us what kind of truck and engine you have. I never heard of a engine water gage?
  4. tmlonghorns
    278
    43
    Mar 12, 2009
    Gregory, MI
    two water gages in my truck
    1. Water Temp gage
    2. Engine water temp gage
    what is the difference?
    If I turn my fan on will that make the engine water gage temp decrease? What will running the fan do for mileage?
  5. tmlonghorns
    278
    43
    Mar 12, 2009
    Gregory, MI
    1989 International 9307 with the 3406 Cat motor.
  6. ynot
    ynot Bobtail Member
    24
    10
    Apr 12, 2009
    Iowa
    Your engine temp gauge is bounding that hi from either being low on water (gauge peds in air) or you have combustion (head gasket, air comp, whatever).
    The four gauge sendors you CAN have on coolant:
    1) Coolant temp (1 pole, 3/8" nut)
    2) Overheat idiot light sendor (1 pole, 11/32" nut, red top)
    3) Low coolant sendor in the rad (3 or 4 wires depending on external grounds)
    4) Horton (Bendix) fan switch (two poles; hot in, power feed out)
    Running the fan full time drinks fuel, and you're not fixing the actaul problem. Good luck tho!!...
  7. Heavyd
    Heavyd Road Train Member
    7,772
    6,210
    Feb 4, 2009
    International only has one gauge for engine cooland temp. Chances are the second gauge is either a custom installed gauge or a second water temp gauge in the engine oil temp gauge spot. (some you can switch spots) The fan switch will be for the engine fan. If your gauge needle is boucing around really quickly then you will have a bad sensor or wire. I would need to get my manuals that I don't have access to a home, but I think you would have just a single wire temp sensor somewhere near the waterpump or rear of the oil cooler. With the age of the truck, I would bet the wire is corroded or loose somewhere. If the needle bounces really fast I would say it is a gauge/sensor/wire problem. You have realize that engine coolant doesn't change temperature that quickly. It takes a while to warm up and cool down, it is a slow process.
