GCWR 23,500 lbs (2016 F350 SRW) and 36' enclosed utility trailer triple 5200# axles
Discussion in 'Expediter and Hot Shot Trucking Forum' started by mmartinez813, Jan 10, 2023.
  1. mmartinez813
    mmartinez813 Bobtail Member
    Can I make any money with this setup? Both are paid in full and was looking for a career change. Researching here suggests a fair amount of money and effort to get going: insurance, registrations, etc. I have no issues meeting the requirements, but trying to do a cost benefit analysis. Any guidance helps. Thanks.
  3. Slay
    Slay Light Load Member
    130
    134
    Jan 7, 2015
    Unless you can find a niche that needs the covered trailer I would say this is not an ideal setup.
    Look at your trailer for the info tag. Find the GVWR of the trailer and subtract the empty weight of the trailer. This will give you the payload for the trailer.
    You might be able to get some work delivering appliances or furniture but make sure you have the correct insurance. However your trailer is not dock high nor is it big enough to load it with a forklift.
    Right now is not an ideal time to get into trucking. The rates are very low. The number of loads are way down also.
    Lite bug Thanks this.
  4. mmartinez813
    Thanks for the advice. I have lots of free time and was hoping to make some money with what I already had. I'll focus efforts elsewhere.
  5. Brandonpdx
    Brandonpdx Road Train Member
    3,898
    3,598
    Dec 27, 2007
    Elkhart, IN
    Dry van is not really a thing with the small trucks is because the trailer needs to be dock height like a standard semi-trailer. Not saying it doesn't exist period but that isn't where you'd start unless you had somebody lined up to haul for that specifically needs that. It's going to either be general flatbed freight or vehicles. Other niche markets for small trucks are hauling smaller trailers on a bigger trailer, such as RV's, enclosed cargo trailers or boats.
  6. DRTDEVL
    DRTDEVL Road Train Member
    1,466
    2,943
    Jan 27, 2013
    Austin, MN
    You may want to re-look at the numbers. A 2016 F350 SRW has a GVWR of 9800 lbs. Your trailer likely has a GVWR of 15,600, putting your combined DOT GCWR of 25,400... legal without CDL. *BUT* Ford stated the maximum GCWR for the SRW F350 was only 19,000 lbs in 2016.
Draft saved Draft deleted
