Gear box/Steering box leaking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by topcat1974, Sep 17, 2013.
  1. topcat1974
    topcat1974 Light Load Member
    119
    31
    Sep 12, 2010
    Charlotte, NC
    Hello, I've heard that you can get kits to rebuild your steering box yourself, but from where? Also it making a popping noise. Maybe I just need to buy a new one. Just need to rebuild or replace.
  3. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    are you sure the popping noise is coming from the steering box? could be spring shackle pins,bushings.
  4. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    I would like to know myself where to get the steering box rebuild kit if its available in the market.
  5. RedRiver727
    RedRiver727 Bobtail Member
    11
    10
    Sep 16, 2013
    McCook Ne
    Yes you can get the rebuild kit I just bought one for my 379 I think I paid around 200.00 for the kit I got to looking at mine tonight took the cover off on the steering wheel side put some silicone on it and it quit leaking
  6. 4vmach1
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    thx, dealer or a special website?
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    For TRW input seals, the part # is TAS000001. They are faily easy, you can get that and most dealers and parts places. Getting the seal in and to the correct depth is the hardest part. As for the whole thing, you can order a kit from anyone who sells TRW boxes, but I caution on doing it yourself. It is not a hard job all in all, but it is very easy to screw up too. TRW has some good instructions on thier website, but they need to be read, understood and followed very well. Things need to be very clean and things need to be checked very closely.
  8. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    When you use re-builds its very important to make sure it's just the seals that are leaking. And why the seals failed. If the are dry rotted and worn a seal kit may do the trick. But if they are worn and torn, buy a new box don't play around. If the worm gear is slightly off it will ruin the seals within a matter of days/weeks. And a re-build kit will not get rid of excess play like a new one. I've done it both ways and both have worked. But the kit can give people problems if the issue is deeper then a seal kit.
  9. RedRiver727
    11
    10
    Sep 16, 2013
    McCook Ne
    I got it at parts store
  10. Heavyd
    Heavyd Road Train Member
    7,808
    6,258
    Feb 4, 2009
    Steering gears aren't something to be messing with if you don't know what you are doing. You are taking total liability in your hands if something goes wrong. This is steering you're playing with, not clearance lights or chrome hub caps. Like Largecar said, most seal leaks are due to worn or scored parts that installing a new seal will not fix. Rebuilding of a steering gear is not for a do-it-yourselfer!!! I understand we all want to save a buck, but this is one area I highly recommend to just buy a complete reman gear and install it. Changing a gear is certainly something you can do yourself and save some money. Shop around for a reman gear. Get a reman gear with a warranty, install it, and get back on the road. Don't waste your time patching a worn out leaky gear.
