Gear changing and braking help
Discussion in 'Questions From New Drivers' started by Carmine, Feb 19, 2016.
  1. Carmine
    Carmine Bobtail Member
    11
    Feb 1, 2016
    Perth
    Thanks, i'm aware of this i was thinking of learning on some quiet roads first. I already left foot brake in auto cars btw so i have some experience.
    also why would you hit your head driving the autos? too heavy on the left foot?
  3. Carmine
    11
    Feb 1, 2016
    Perth
    Yep you've got it, i'm just trying to work out a technique to use the service brakes with the engine brake for times when the engine brake alone wont quiet to the job fast enough.
    Currently i just brake in between down changes but it seems to me that there must be a better way.
    Also do you have any tip for double or triple gear changes?
  4. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    As a new driver, I had the same concern when approaching a stale green light or coming up on a blind red light.
    Assume I am going 45 mph in moderate traffic and I need to decrease my speed faster than just using the jake and downshifting. I apply the service brake as needed to reduce speed and shift to neutral. The only way to stop is to use the service brake, so I focus on that pedal for a quick smooth safe stop. And I know I will want to be in 1st or 2nd gear to start if I am loaded. I can't grab 2nd gear until I am almost stopped, and using the jake in 9th gear is not going to stop me.
    The only choice is to use the brake to safely stop. You simply do not have time to downshift - maybe one or two gears- but that only drops you to 35 mph.
    This allows you to match your available stopping distance to the amount of brake pedal pressure that you apply. And make a safer stop.
    There will also be sudden traffic changes where you need to drop speed, but not stop. That is why I shift to neutral, as I am then ready to grab the gear I need to roll on at 10, 15, or 20 mph. I glance at the speedometer and use this guide to pick my gear:
    15 mph = 6 th gear. (1 + 5 = 6)
    25 mph = 7 th gear. (2 + 5 = 7)
    35 mph = 8 th gear. Etc.
    45 mph = 9 th gear
    Easy to remember....this method has worked well for me.
    Keithdabarber and Lepton1 Thank this.
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    Again, each truck is setup differently, but a general rule of thumb is downshift two gears when the Jake cancels at 800 rpm's or 3 gears if you drop to engine stall speed at 600 rpm's. This is assuming flat terrain.
  6. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    ....I brake with my left foot (lightly) and use my right foot to float down as far as I can. Took some practice, but it's fluid now
    Carmine and wp77 Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Experience grasshopper... Wax on wax off, grasshopper. Until then you're only going to get confused with all the different approaches to do the same thing ... Stop
    It's not that hard and don't make it more complicated than it needs to be.
    Work out all the fancy "big trucker" stuff later when it makes more sense.
    roadmap65, truckdad and Lepton1 Thank this.
  8. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    That's the thing I want to point on. With the left foot, you're used to press the clutch. And this means the pedal all the way down. And that's where the trouble starts when you use the left foot for braking.
    It takes a lot of concentration to do it properly and you could lose your focus on what you should do COME TO A STOP.
    I've tried it yesterday after I read this and I keep on doing what I did already before. Use the Jake to slow down and shift down. If it's more of a surprise, kick it in neutral a use the service brake.
    Like other posters already suggested, allow yourself plenty of room (following distance), be prepared and slow down on a stale green light. This will prevent hard brake applications.
    Many companies have the "Critical Event" activated in the Qualcomm. Getting a critical event and you will be reported. And this are the reasons for it:
    - Driving too fast
    - following too close
    - distracted driving
    Those events are easy to avoid. If you have one event in a month, nobody would bother. If you have one or more a day, possibly somebody is raising an eyebrow.
  9. wp77
    wp77 Light Load Member
    72
    77
    Jan 20, 2015
    This is the same thing I do. You should practice doing this before you get into one of those emergency stop situations.
  10. Carmine
    11
    Feb 1, 2016
    Perth
    Do you think you could make a video of you using that technique? (or someone else doing it)
    Can you use the technique in a cab over or does the steering column get in the way?
  11. wp77
    72
    77
    Jan 20, 2015
    It would be impossible to make a video of this safely.
    As far as doing it in a cab over, it would just depend if you have room to move your feet or not. I'm guessing every truck is a little different.
