Gear for Flatbeding in the Northeast Winter
Discussion in 'Questions From New Drivers' started by Ridgerunner412, Aug 29, 2008.
  1. Ridgerunner412
    Ridgerunner412 Bobtail Member
    8
    Brockport NY
    What kind of work gloves should I buy for flatbedding in upstate NY this winter. I work for a Lumber Company, and make 4 to 10 stops a day with a day cab. I am constantly strapping, unstrapping, re-strapping and tarping the load. I need warm Waterproof gloves that are flexable enough to work with straps and rachets. They also need to be tough enough to last more than a week. I an planning on Red Wing insulated work boots, Carhart bibs, and Jacket. Any suggestions would be greatly appreciated!
  3. kaiwren986
    kaiwren986 Light Load Member
    178
    55
    Aug 9, 2008
    Lowell, IN
    I've been through all sorts of gloves, I did a lot of heating work in dead winter in the steel mills with my dad when it was ### cold out. And believe it or not I thought the best combo for being able to move my hands and stay warm was, some of those cheap $5 CAT gloves you get at the gas station, and a pair of Mechanix gloves, just layer them, Mechanix gloves on the inside, Cat gloves on the outside since they're more flexible, and the fingers and palm are rubberized, will keep you dry(er) not nearly as bulky as normal winter gloves.
    They should keep you warm long enough to do your thing.
  4. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    My advice on gloves for winter would be once you find something you like get 5 or 6 pairs so you can switch out when they get wet, I have found no matter how "water proof" they are they will still get wet..
  5. im6under
    im6under Heavy Load Member
    782
    406
    Feb 13, 2007
    iowa
    cheap brown jersey cottons on the inside with a rubberized pair as an outer shell.
    the outers are 5 bucks and the inners are .99 cents. $20 bucks will get you enough to last all winter...
    which is better than a single pair of nice gortex gloves that either get a hole in the finger or get wet and you freeze anyways... lol
    each to his own... my way looks cheap and gaudy (it is) but it works...
  6. User Name
    User Name Light Load Member
    143
    36
    Aug 20, 2008
    Midwest
    Eactly!
    I also rolled my straps & put them in the passengers side floor when I was done till they were dry & then I put them & kept them in my tractor side box.
    Most of the handling you'll do is with the straps (unless you're tarping), it helps to have them dry & flexible to start with.
