gear ratio and axle specs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fredrd, Oct 23, 2015.
  1. fredrd
    fredrd Light Load Member
    153
    8
    May 10, 2012
    i am building a single axle refrigerated van, dealer has me in a gear ratio of 5.63 and axle config of 10,000 front 23,000 rear. meritor wide beam truck weight distribution without the reefer box is 6900/4200. truck i am replacing is 12,000 front and 21,000 rear.(33,000) also changed from sfa to sba. does this sound right? should i have the lower front axle for the stronger rear? truck grade ability at this gear ratio is 48.04%/2.42%@55mph
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Dear lord is it a 150hp motor????
  4. AModelCat
    158,343
    I wouldn't think having a heavier rear axle will compensate for having a lighter front axle. Not sure what the regs are in the US but a single drive axle is only legal to I believe 9100kg/20,000lbs in western Canada.
  5. fredrd
    153
    8
    May 10, 2012
    325hp Cummins isb
    I know my 12k front 21 rear had been ok for a 24ft box.. I just don't know if a 10k/ 23 k config is that much of a difference to worry about
  6. fredrd
    153
    8
    May 10, 2012
    Why do you say 150 because of the gears? It's 325hp for a little box truck. I have 3.90 gears on a 350hp and it's a dog down low
  7. Ruthless
    Ruthless Road Train Member
    8,931
    87,834
    Aug 28, 2010
    The City.
    I'd think as long as you push that rear axle forward a bit to make sure you aren't ending up heavy on the steer you'd be fine.
    Would it hurt to put a 12k steer and a 23k rear? I'd rather overbuild a bit than feel like I'm gonna be whooping on something...I sure there's a difference on the price tag.
    snowman_w900 and drdesl Thank this.
  8. drdesl
    drdesl Light Load Member
    218
    388
    Oct 7, 2015
    Billings, Montana
    Good Lord, upgrade to the ISC 8.3. You will not regret it over the B 6.7
  9. fredrd
    153
    8
    May 10, 2012
    Do you really need more power in a little straight truck?
  10. fredrd
    153
    8
    May 10, 2012
    Problem is over 33000 gvwr federal excise tax is like $8k extra
  11. Ruthless
    8,931
    87,834
    Aug 28, 2010
    The City.
    Reg it lower?
    Id rather have more truck than I need than save $8k and break something.
    I have a 10 wheeler @ 475horse. Rarely over 33k gross & it's gotta be at least 22 tare. It's real laggy compared to my road tractor.
    If you are buying it, and you are driving it: I don't think there's such thing as too much power.
    drdesl Thanks this.
