Gearing for 1994 T800 Kenworth
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nmiller1066, Mar 11, 2021.
  1. nmiller1066
    nmiller1066 Bobtail Member
    Hello. We are putting a 1994 T800 Kenworth into OTR service. It is currently at 900k miles on original differentials.
    The truck was built with 3406B CAT, Eaton RTX14710B 10-speed trans and 4.33 gear ratio in the drives. Of course this truck needs 2000 RPM to get 65 MPH. What is the best solution to get a reasonable cruise RPM at 65-70 mph?
    We have 24.5 tires. Thinking to have the rear-end rebuilt (probably needs it anyway at this point?) and have it updated to 3.55?
    What about the add-on transmission gear option? Seems there is some type of retro kit for these Eaton transmissions? Our transmission is new (Kenworth rebuild) along with the clutch so thinking not to touch it unless it is the better option.
    Thanks in advance!
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Looks like a .74od
    That's as fast as you'll get w/o changing rears or trans. The only trans option would be an older RTOO with the .62od and that will only drop your rpms by roughly 200
  4. nmiller1066
    Thank you Brett. It is a .74OD. Looks like we will have to change our rears to 3:55. We were quoted $4500 but seems that's what its going to take.
  5. Brettj3876
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Do you have low pro 24.5? Something is odd about 2000 at 65.
    4.42 and tall 24.5 .73od puts me at 1650 at 65
