So, lets say I was nuts. Lets say I was crazy enough to buy a truck in these days. Lets say I was going to hypotheticly get something used, with say around 500k miles on it. Here are some questions.
Considering tractors such as the Peterbilt 387 or a Mack CX613. (not to exclude others, but staying way from flat noses)
What engine, gearing, transmission number of gears, and tire's produce the best MPG? Can you go up to a 500HP engine with the right gears? If not, what is the max HP one should look into? What gearing? Are Detroits better then Cats for Fuel econemy? or vice versa? Does the make even matter?
Basicly, if fuel econemy was the primary factor, what is the best engine/gearing/tire size combo to be looking for? How does it change when looking at a 10speed compaired to a 13 speed or 18 speed? What about when you throw an autoshift in the mix?
Then after that, if I was going to consider giving and taking mpg just a little to say.... climb better, what would I give and take?
And what the hell, throw in anything one would need to know when deciding between a CAT, Cummings, Detroit, or Mack engine.
Thanks in advance.
Gearing / Tires and Fuel MPG?
Discussion in 'Ask An Owner Operator' started by wc5b, Mar 13, 2008.
Fist question is what do yo want to do? OTR.? Regional?
Flat? Dry? ......North? South? East coast? West of Rockies? I need more info to help you. -
OTR lower 48. Random routes. So, ya, mountians would be seen. Prob Dry and Reefers. Tanker here and there. But rare.
Also why I like the 387 and CX613. They nice and comfy sleepers. I like to stay out awhile. -
First off; forget about the Mack. Mack motors are not known for fuel mileage. Secondly, it is more difficultto find parts and service for a Mack when you are on the road.
You should be looking at Pete 387's, KW T2000 and T600, or frieghtliner Centuries or Columbias.
Detroits are usually the best motor for fuel mileage, although a cummins does a good job as well in that department.
As for spec'ing the truck; the most important thing that I need to know is; how fast do you plan to cruise? You need to decide that first, then spec the truck so that it runs as efficiently as possible at that speed. -
Like has been said you have to spec it for your driving style and speed. If you are going to run out west where its 75 mph speed limits spec it to run in the sweet spot of the motor in high gear. and the Detroit is going to be your better eng for that. Now as to trans i like a 13 double over but thats me every one to there own taste. Some like the 18 some like the 10 if your going to be in the mountains you want a trans that is going to let you keep it pulling. Now as to the tires highway non lug will get you better fuel millage but you loose the traction that is required in bad weather so its a pro con thing i always ran lug tires on drives and averaged over 1.4 million miles on a truck with about 5.8 miles to the gallon on a fld 120 with a 430-470 Detroit and 13 speed with 3.73 rears i missed the gears when i ordered it the speeds were at 65 and then they jumped so i missed the sweet spot should have been 3.55 or so and it would have been better and could have jumped it to 6.2 or so. Now horse power and fuel millage are not going to change unless you get to little horse power so get as much as you can just cause you have doesn't mean you have to use it. A 550 or 600 horse motor will get as good if not better millage than a 400 or 450 motor if driven right. The driver has as much to do with fuel millage as the equipment and gearing has the most to do with fuel millage. Ok thats my take and my feelings on the subject and as far as which truck and model as long as you stay away from the square hoods you will be fine on the aero side now me i will sacrifice a little fuel millage for the hood but thats just me and my taste.
scatruck Thanks this. -
