gearing vs mpg whats your input???
Discussion in 'Peterbilt Forum' started by doublew, Jan 7, 2011.
  1. doublew
    doublew Light Load Member
    68
    7
    Oct 17, 2010
    Kansas
    i have a 95 379 pete with 550 hp cat with 2300 550 hp brake saver program in the ecm 13 speed and 3.70 rears getting 5.5 avg if i run 65mph at 1500 rpm i have been thinkin about putting 3.36 rears and dumping the 3.70 ...i have talked to some other o/o that have done this and some say they are getting upwards of 7.0mpg not sure if i believe that but wanted to get your thought..what are you gettin and running
  3. Gambi80
    Gambi80 Medium Load Member
    Daycab, 3:90, 18sp, 22.5 tall, N14 525hp, 1500 rpm at 65 mph.......can't say I'm settin the world on fire, but it's ok. If I cruised down the highway for hours on end it might be better. But for now, it's between 5.5 and 7.5.
    I wouldn't mind somethin a bit taller...maybe 3:70.
    Trucker Nunnery Thanks this.
  4. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    a guy in our fleet is running the same truck as you set up wise and he is running 4.7 hauling 105,500 from northern ID to wester WA, i think 3.42 or 3.55 would suit you better than the 3.36 unless you wanna run 75 then go with the 3.36
  5. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    My '95 435HP 5EK/ 15 speed/3.36 has lifetime average of 6.23... pulling flats and vans...
  6. Rig Wrench
    Rig Wrench Medium Load Member
    398
    66
    Dec 24, 2010
    northeast
    What are you hauling and where? i cant speek for everyone but the experience that i've had where i work we are actually seeing better mileage with 4.10's than with 3.90's. i will add that we do not do a lot of highway hauling, i would say 70/30 with the more being two lane roads, lota hills, back roads, comstuction type hauling, (lowboy, dump trailer, walking floor, etc). It seems that the lower gears allow u to select a higher trans. gear dropping rpm. THIS is not true for everyone, most likely not for you, just my .02. we also haul mostly overwieght 107k and up.
  7. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    99 Flat top 379 With 475 hp CAT 390 rears 10 speed and 24 tall rubber.General D66o on Drive axles. 6.6 pulling a flat 75000 to 80000 gross most of the time. 32000 empty. 63 to 67 mph across I-10 Mostly Flat plate steel. This is using my home made APU at night or anytime I am sitting and waiting. Truck has 1,520,000 miles. 400,000 miles on rebuild. If I slow to 57 - 58 I can get 7.2 to 7.3
  8. jr-transport
    jr-transport Light Load Member
    Dont trust what your computer says- I check my mileage after every tank and i get about 0.6-1.4 mpg worse than the computer says. I have 2 trucks and ill give the numbrs for when i pull small loads (tri axle 95 000-105 000 lbs)
    -2005 379X-600+ MXS C-15 70in bunk, 244 wb, 18do tranny 4.11 gears (it used to have 3.90's and before that 3.36 and there was very little difference, if any in mileage) runnin' 55-65 mph gettin' about 4.8-5.4 mpg depending on wind and time of year.
    -1999 379 EXHD Series 60 12.7L Jimmy, 63in standup bunk, 244 wb, 13 spd, 3.90 rears runnin the same haul, same driver as the other truck averaged in the summer months 6-6.3 mpg and about 5.6-5.8 in the winter. I even got it up to 6.7 once.
    These numbers are taken over abut 2.5 years of hauling logs in SE Manitoba, NW Ontario and NW Minnesota on flat land and driving nicely.
  9. mc8541ss
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    I also always check every tank full. I don't have a computer that calculates mine.
  10. PaidByThePound
    PaidByThePound Bobtail Member
    47
    12
    Jul 19, 2011
    Bellevue, IA
    from what ive read the 3406's and c15's are best matched with 3.55 and the acert motors are best matched with 3.36 fro best fuel mileage. 3406/c15 like 200 rpm higher than the acerts for best fuel mileage.
  11. Infrared61ranger
    Infrared61ranger Light Load Member
    149
    36
    Dec 15, 2011
    killeen,tx
    drop the Peterbuilt and get a freightliner with a detroit motor better areodynamics and better fuel mpg. Wont look cool and no need to add chicken light.
