geartronic shifting
Discussion in 'Volvo Forum' started by ah fai, Oct 12, 2012.
  1. ah fai
    ah fai Light Load Member
    178
    anybody familiar with volvo geartronic shifting?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I do, not the best tranny, but good.
  4. ah fai
    178
    ok, correct me if i m wrong, the gear shift knot show C, R, 1/4, 2/5, 3/6, AUTO and Hold...if in auto mode it should be running in fully auto but we can still shift up or down gear by the split button. but i dont know how if i want to shift in manual mode...
    any idea?
    the gearbox is 12+2 forward gear and 2 reverse?
    and if going down hill, how to select a gear for better engine brake?
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    use auto. C- is lowers gear for heavy conditions (crowler)
    In manual mode you can use any gear you want.
    Yes, it si 12+2 tranny, in the USA it is called 14 st, in Europe they call it 12 st +2
    when you run down a hill you can use downshift buttons in auto mode. But when you accelerate ore slow down tranny switches to auto mode selecting other gears
    1/4 2/5 3/6 is imitation of manual shift pattern, range is lesected automaticly
    ah fai Thanks this.
  6. ah fai
    178
    ok, in manual mode, i shift from 1,2,3 and go for 4 gear just shift the gear knot to 1 gear position and they will change to high range to continue with 5,6 gear right?
    every gear can shift with splitter button means half gear?
    thanks alot
